Quote Originally Posted by angelgz
Can any of your give me some suggestions as to if I should replace these to hear a difference? According to someone, when he replaced his cables on the Krell system, it made a huge difference just night and day.
Night and day you will not find even if you bought Nordost Odins for your system. There are degrees of improvement, but they are incremental. While I particularly like JPS Labs stuff, you might try out some relative inexpensive, but good value Belden cable found in the Blue Jeans Cable line. I use some of their digital ICs from transport to DAC and a set of BC-1 ICs from DAC to power amp. BTW, what is (are) your source(s)? Shielded low capacitance cables can really improve the run from CDP to preamp. I would also recommend looking into some power conditioning. Especially since you are a classical music fancier, I've found that such can lower the noise floor which is more apparent on wide dynamic range acoustical content.
I've always listened to relatively expensive stuff at home in my system on a trial basis. That's really the only way to determine whether or not a given higher priced spread can offer real benefits to your system.
Good luck!
