Quote Originally Posted by risabet
... or whether or not taste sweet, salty, bitter, or tasteless.
You are right of course.
Now say I had two foods which were identical except one had sodium benzoate in it. I had both of them on a table marked A (sodium benzoate) and B (no sodium benzoate) and A had the sodium benzoate. I taste both of them and tell you that I can taste the sodium benzoate in A but not B. What value does my test have for you? What would your reaction be?
Well, it should be to make me redo the test, get a licensed tester, remove the markers, have the friend switch the plates around and do it several times. Then the tester can produce a score card. Now, if I picked A 19 times out of 20, you could say the test was positive. Now we could use other people of varying capabilities, we could change the amount of sodium benzoate in each dish, we could use different base foods, etc. Now that's SCIENCE 101.
I don't see any of that in audio so claims of cable sonics are right up there with claims I can tell Pepsi from Coke while holding a can of each in all their blue and red glory.
