(snip all that was totally irrelavent.)
Cable differences are subtle and my ears need time to get used to their sonic signature. Even so, I didn't score perfectly but I would have done less well with rapid switching.
How do you know?
Unfortunately, the rapid switching so common in the area of testing audio components (not that I can find much evidence of testing!) will usually give the null result, thereby adding fuel to the objectivists fire that "it all sounds the same".
Sorry, but this is just not true, which is why there is so much testing using such a method. To make sure we are on the same page, when I say rapid switch, I mean two devices switched by a mechanical method - as opposed to someone plugging and unplugging cables.
I have also participated in numerous tests and I can assure you, the results were anything but null.....we weren't testing cables, but where there were differences, they stuck out like a sore thumb using rapid switching. Listening to each device seperately would have certainly yielded more nulls.
-Bruce
