Results 26 to 50 of 58
Like Tree4Likes
Thread: DIY Balanced AC Power Conditioner
Threaded View
    New York
    I just recently completed construction of my DIY balanced power AC line conditioner and thought I would post some pics. It employs two separate transformers, one for analog components and the other for digital, each preceded by its own EMI/RFI filter. The two sections share only a common circuit breaker and IEC power inlet.
    Parts List:
    2,000VA and 250VA balanced isolation transformers.
    Qualtek high-current EMI/RFI filters.
    Furutech FP15A silver duplex receptacles.
    Auricaps.
    Pass & Seymour 20A dead -front GFCI switches.
    Carlingswitch 20A hydraulic-magnetic breaker.
    Schurter 20A IEC inlet.
    Par-Metal aluminum & steel chassis.
    Mono-crystal and OFC wire.
    Miscellaneous hardware.
ID:	538   Click image for larger version.
ID:	539   Click image for larger version.
ID:	543   Click image for larger version.
ID:	545   Click image for larger version.
  2. First experience with power conditioning
    By Mr Peabody in forum Cables
    Last Post: 06-20-2006, 08:09 AM
  4. Replies: 18
    Last Post: 12-20-2003, 04:18 PM
