Results 1 to 25 of 34
    Nueva Jork
    Well for one thing...
    ...there is ZERO relevance to the cryogenic treatment of tool steel and the like on the molecular and subatomic levels to that of copolymers and the polycarbonate of your CD...You must understand how steel is forged and quenched and how it affects it's physical structure. Cryo goes a step further by "removing" unwanted "impuities" left in the end product...It results in a harder and more crystalline structure, the better to take and hold an edge as in the case of cutting tools. Curious thing is that some cryo folks say such treatment actually makes metals like copper more maleable...hmmm, something seems askew there!
    HOWEVER, CDs are merely a data storage medium and as such the cryo scheme would somehow have to make the polycarbonate "clearer" to improve the light transfer characteristics. To my way of thinking, somehow increasing covalent "density" does not go hand-in-hand to that end.
    The laser is spec'd to be able to read the "pits and lands" in the sputtered aluminum substrate...it's zero's and one's, on or off; the entire basis for digital anything rest on this simple premise...no gray areas. Sound is not "produced" in the same sense as it is in an analog medium and it's not even done in realtime.
    The laser is kept on track and in focus by various control programs and once the data has been read, the math is done and any errors seen in it are corrected for by CIRC(Cross Interleaved Redundancy Code)...you either get program material or you don't, again no gray areas. After sufficient coherent data are stored in the buffers, it then goes through the D/A processors and the player's analog output circuitry. Here is where all, if any, sonic anomolies take place...
    Given the potential for stress fracturing when exposed to temperature extremes, the fact that a CD can withstand DCT and still play at all, is a testament to it's hardy chemical composition and should be a reminder of "...if it ain't broke, don't fix it..."
    But heck, if you can get someone to pay a coupla' hundred bux to have an already overpriced $79 Oyaide AC outlet subjected to the big chill, what's another $6 per CD?
    jimHJJ(...I see the outlet eliminates "micro-arcing"...whatever that's supposed to be...)
    I live in NY. Can't I just through my system out the window for a few days in January?
    Nueva Jork
    Well...
    ...even if you took wind chill and any residual lake-effect into consideration, I don't think it would be quite cold enough...
    jimHJJ(...and besides it requires the proper technique...)
    How about if my wife gives it the cold shoulder?
    Nueva Jork
    Now that's...
    ...a whole 'nother kettle of fish...
    jimHJJ(...in MY experience, Gorton's perhaps...)
    Jul 2005
    Exclamation
    I wonder if these things are Cryo-Treated too...... .... http://www.audiocircle.com/circles/v...ic.php?t=22961
    Mutant from table 9
    Mar 2005
    Nice Fatty Arbuckle reference. Fatty... the true trial of the century. And, he really was innocent.
    I got yer cryo treatment right here. Soak your garbage in a bowl of Listerine for five minutes before rubbing one out and it will feel like someone else is doing it.
    Nueva Jork
    I wonder what...
    Quote Originally Posted by Soundideas
    ...the proper pronounciation is...sonic-rock or soni-crock?...
    It's all out there...from harmless and cheap DIYs like sand filled zip-locks to Mpingo blocks and unconscionably-priced "audiophile-grade" wooden control knobs...caveat emptor.
    jimHJJ(...my fave is still the proprietary substance that was once called "stardust"...)
