With a Technics S-shaped arm, you just need to align the cartridge straight ahead in the headshell and at this distance...
This is the dimension of the Technics tool in the video. Using the paper protractor is good, but maybe not any better than the Technics method. I noticed the Baerwald protractor in the video. Aligning to that protractor will look a little odd if you get it right. It will be pushed forward and angled in, as compared to the Technics method.
Another approach is to go by the specified overhang. For the SL-20, the overhang is specified as 14 mm. Which means with the cartridge straight ahead, the dimension in this picture would be 14 mm when you swing the cartridge in to the spindle:
I'm planning on setting up the cart tonight. Which approach should I take? Any need to clean any part of the arm or connections? With the measurements, are you guys just using a regular ruler?
Thanks for the help fellas.
E
