What did you drive the Totem with at high volume?
The amp used for my auditions was a Jolida 302BRC. I'm thinking (and as you mentioned in another post) something with a 6550 would perform better...for me enter the Jolida 801ARC.
Quote Originally Posted by ken88 View Post
Mitchellin, I already have the Totem Sttaf, Mite T centre and the 2 Mite compacts as surround. I am very happy with this set of 5 speakers. The only thing I wish more with the Sttaf is to have deeper bass. When I review the Monitor Audio RX8 , I read that they have much deeper bass and I am thinking to myself if I replace the Sttaf with RX8, may be I would then have a "perfect"system. Is this a good idea? What are your thoughts?? Thanks.
I auditoned the RX8. That speaker will produce some decent bass. What I found it failing at was mid, mid-bass, and the upper register. Too much sibilance for me in the mids, murky mid bass (lacking punch and definition), and the highs were WAY to bright. I moved about the room (off/on axis), changed up the discs I brought, played with tone control, moved the speakers around a bit, and nothing helped the areas that seemed unnatural to me. I moved on.
Just me, I would not sacrifice the middle and upper register of what the Sttaf can bring to my ears. Bass (or lack of here) is the issue. What sub have you employed in your system?
