Results 1 to 25 of 31
    Dec 2009
    I am comparing, say, the floor standing Totem Sttaf v/s Monitor RX 8. Any opinions?? Thanks.
    I personally would choose the Totem. MA can be system dependent, on the wrong gear I would find them a bit fatiguing, but that's my taste, the highs are very lively, they do have good bass. The Totem I've heard had a balanced frequency response, no one area drew attention to itself but nothing was lacking either, and excellent imaging.
    What will you be driving them with? Just stereo or are you doing home theater?
    Dec 2009
    I have the receiver Anthem MRX 700 to drive the 5.1 speakers system. I will be using the Totem /MA as front speakers and I listen mostly to music although I watch movies 25% of the time.
    I'm not familiar with the Anthem receiver so not sure which would mate best. What are you using for center?
    Dec 2009
    I got the Totem Mite T as centre speaker.
    Charm Thai™
    Cleveland, Ohio
    Not a fan of any Monitor Audio speaker whatsoever but I have heard some Totem's that i liked. The Model one, Hawk and Forest are decent but for what they are but maybe priced just a tad bit higher than similar competitors. Plus Monitor Audio speakers are so damn ugly to look at, bleh.
    Having a Totem center is a good reason to go Totem mains, even if not a perfect timbre match with the model you get it would be closer than using Monitor Audio.I haven't seen the Silver series but the new Monitor Audio Gold looks pretty good with the piano black finish.
