Results 1 to 4 of 4
    a hell of an engineer
    Sep 2004
    I'm not entirely sure what is causing your problem. The first thing I would check is the connection between the subwoofer cable and the subwoofer. Is the plug all the way in and is the connection snug fitting and not loose? I would also check the connection between the subwoofer cable and the receiver. You may need to replace your subwoofer cable if the connections are not snug. Another thing you might try is to place an EMI filter between the subwoofer AC plug and the wall outlet. I think you can get one from Radio Shack. Also, some surge protectors have built-in EMI filters.
    It would help to know exactly when the crackling occurs.
    The Noise comes and goes, I have a monster cable connected to the subwoofer and it has a solid connection. I will try a surge that blocks emi.
  1. klipsch subwoofer
    By perceptionof222 in forum The Audio Lab, Tweaks, Mods, DIY
    Last Post: 01-21-2005, 06:26 AM
  2. Ground loop in subwoofer -- did my printer create this?
  3. Replies: 1
  4. Looking for a Subwoofer under $400
    By agidol in forum Speakers
  5. Do you know if this subwoofer is any good?
    By polo13 in forum Speakers
    Last Post: 12-13-2003, 12:43 PM
