Results 1 to 9 of 9
Threaded View
    Forum Regular Registered Member IvanZ's Avatar
    Apr 2019
    Yekaterinburg, Russia
    PLK — WAGNER acoustics
    PLK — WAGNER
    We present to your attention a professional two-way speaker system, model Wagner.
    Impeccable workmanship, high quality components and the best acoustic solutions satisfy even the most sophisticated listeners. Appearance of the Wagner system sets a special atmosphere of nobility and solidity, playing a decent party in any of the most refined interior, emphasizing the high status of their owner.
    The principle of sound from one setup implemented in the system creates for the listener the only true sound architecture: having heard it once, it is no longer possible to be content with something else.
    DRIVE UNITS
    The fifteen-inch speaker easily saturates the area with sound, revealing all the emotions of a piece of music, preserving the delicacy of presentation and accurately conveying the scale of a composition. The high-frequency driver, located in the center of the main speaker, thanks to a specially developed frequency filter, harmoniously merges with the main speaker, which gives the sound absolute wholeness and realism.
    Internal structure of the Wagner system developed by our engineers, without exaggeration, represents a unique acoustic instrument. During its development we succeeded to achieve absolute neutrality of its sounding, imported with inexpressible freedom and lightness of sound.
    Uncompromising approach of our experts in the choice of acoustic solutions allowed to create the sound that can be enjoyed for hours. The main advantage of the Wagner system is the emotions, joy and happiness that they carry, keeping their owners in the world of music for hours.
    TECHNICAL SPECIFICATIONS
    Recommended amplifier power 50 – 450 Watts
    Consumption power handling 300 Watts
    RMS Frequency response 32Hz – 22kHz, (-6dB)
    Sensitivity 99dB (1Watts / 1m)
    Nominal impedance 8 OhmsTypeTwo-way
    DRIVE UNITS
    Design coaxial high-frequency and low-frequency drive units
    High-frequency 70mm (2,8”) witht titanic dome, horn-type,neodymium magnetic system
    Dispersion 80 degrees, conical
    Low-frequency 380mm (15”) withpaper diffuser, neodymium magnetic system
    CROSSOVER
    Frequency 270 Hz acustical, 900 Hz electrical
    Type Bi-wired, passive, low loss, Istorder for LF
    IInd orderfor HF
    Quarter-wavelength resonator
    CABINET
    Enclosure type Quarter-wavelength resonator
    Volume 440l
    Dimensions 1630 х 770 х 640 mm
    Weight 118kg
    plk-audio. c o m
    If you have any questions, leave them. I will gladly answer
