Quote Originally Posted by TSH
I have v2 Titans that I want to use as fronts in a 5.1 system (Atom v2 as the surrounds). I would like to get a CC170 for the center. I know that Paradigm is now at v4. Do I need to find a v2 CC170 to match, or would any version of the CC170 work "right". I am not sure of the differences between versions and whether I would notice them anyway. Thanks.
TSH, I am using the Titans v.3 for my rears and a cc-170 v.3 center. It works fine for me but my emphasis is more on music. The sound is very clear and does not sound tinny or boxy. However, if your preference is on HT then I would go with the cc-270. As mentioned, there is not much difference in the v.3 and v.4 but am not sure about the v.2. Anyways, good luck with your choice and welcome to AR forums.
