Ok members I have a technical question for you. If I understand voice matching correctly then isn't it very important to use speakers by the SAME brand/manufacturer using the same types of drivers in order to acheive optimal imaging AND maximizing the "Home Theater Effect" For example, I am seriously thinking about buying all Paradigm speakers. That is, the Monitor 3's for my fronts, the CC-370 for my center, and the minis for the rears. Hence, the speakers all use the same type of drivers and are in the same LINE/SERIES. So, then why would Ascend recommend a center(cmt-340c) that has a much better tweeter as compared to the CBM-170's. Then, a totally different speaker design altogether for the rears such as in the 200s. I am not trying to disrespect Ascend but am I making a good point? It is obvious to me Ascend makes fine speakers but if the designs are different then doesn't that have an effect on the timbre matching to acheive optimal home theater effect? Many Ascend owners like the cmt-340m for their mains, the cmt-340c for their center, and either the 170's or the 200's for their rears. But, is this truly voice matched? Anyways, I have been pondering this in my head all day. Personally, I am more of a music listener myself but I also want excellent home theater effect. Well, be sure to share your thoughts because the more I learn about speakers then the better descisions I shall make. Thank you for your time.
Phil
