Hi.
I have a Jensen JPS8 subwoofer, and it sounds great. The only problem is that it has a standby mode, which engages after about 9 minutes of inactivity. Whenever my sub goes to standby, it makes a really loud creaking noise (like stepping on an old floorboard). It does this every single time it goes to standby, and its very annoying. Is there any way to fix this? There is a light in the back, and its supposed to be green when its on and red when in standby. When it changes from green to red, it sorta pauses in between and thats when the creaking sound happens. Its really loud and obnoxious. Can anyone help? Thanks.
