help:Dynaudio Audience 60 vs kef reference model one
i'm looking to buy on of theses sets used. i have read all the reviews and they seem equal. i'm looking for a great sounding speaker that has bright highs and good amount of bass. i'll be running these through a denon 2809. i want to buy asap so any feed back would be great/ thanks
You've just described the KEF's perfectly....good amount of bass and BRIGHT highs. If you mate the KEF with Denon then the highs might even get higher.
I used to own a pair if IQ3 Kef speaker and I just could not handle the upper frequencies but it appears you may really like that attribute.The bass was quite outstanding though.
the kef seems to draw a lot of power. what gauge wire should i run?
If this is the Kef Model that you are considering then it's supposed to be an 8 Ohm speaker so you don't need a lot of power to drive them. Speakers that are 4 Ohms certainly require more power than an 8 Ohm speaker.
cerwin vega looks nice but out of my price range. i only want to spend 300-400 for a pair of really nice speakers used. i have been all ebay and craigs list. there are just to many brands out there, i'm so confused
You already mentioned you were going to get a decent sub. If you do that, you may want to consider a really nice pair of Stand Mount speakers to match with a good sub. You are not going to get a "Really Good" pair of floorstanders for under $400 unless you find someone desperate to get rid of something quick. Also, you will need to be concerned with the age and possible need of re-coning older speakers depending on how and where they were used.
EDIT:
I am not the biggest Polk follower but recently got a smaller set for a ridiculous price from New Egg that are fine for my home gym driven with a CDP straight to a Hafler 9180 amp.
If you stretch your budget just a wee bit, you could get these
how do the polks sound? are the highs rich and good bass? they look nice
Polk has it's own sound and I have only heard the Monitor 30s I have and the largest newer ones they have out with the side woofer.
Compared to my Danes or older Clearfields (von Schwiekert), they were not my cup. I got the smaller ones from newegg for like $90 shipped and they are fine for their use.
Have you gone out and just listened to different speakers? It's really hard for people to tell you what a pair sounds like unless you both drive them with the same gear in a similar setting.
I pointed out the Polks because for what you want to spend, you won't find much better unless like I said, someone is giving a pair of good ones away for a steal.
Audiogon is a safe source and their are bargains to be had if you consistently check. The only caveat to Audiogon is the shipping for floorstanders will be mucho. I agree that KEF is a great direction, also maybe Paradigm (although their high frequencies can roll off).....maybe Monitor Audio? But for $300-400 maybe you will have better luck with large monitors, ala Paradigm,Monitor Audio,KEF,KLIPSCH(?), and older B&W. If you go large monitors, I would not go smaller than a 6" woofer, so you don't compromise too much bass.
....oh yeah, for floorstanders what about Axiom? They do not come used very often but when they do they'll be a steal because they are already priced low when new.
I Have the Audience 60's and in my experience they are the best speakers that have been mentioned here but of course that is my opinion and probably not everyone's here. I have had mine for a little while and they do like more power than most receivers can pack so I would not recommend them for receiver use and Dynaudio's musical presentation is probably the some of the most musical out there in my opinion but they are for a certain type of listener kind of like panel speakers and single driver open baffles are as well. They have a depth to them with bass way above their size but they throw detail hard to beat. But through all the people that I know own them and have heard them would agree they have never been good receiver speakers because of their overbuilt nature for their size and rather low sensitivity but for me the over built part means that they will deliver the dynamic goods for their size and will last a long time and always be contender in their class plus they make all their own drivers, cabinets and crossovers as well which usually yields superior results in my opinion.
yamaha htr5560 receiver (HT)
Pass Labs X150.5(2 channel)
Dynaudio audience 60 mains
Yamaha NS-c444 center channel
JBL e250p subwoofer with modified dampened cabinet and after market plate amp.
Samsung 46" LED TV
Dell I660 music server
PS Audio Quintet power center
Blue jeans speaker and interconnect cables
i'm going back and fourth about the Dynaudio Audience 60 vs kef reference model one. the kef are about $100 cheaper. i dont want to every second guess my self. there are to many choices.
