Quote Originally Posted by rightaway View Post
the kef seems to draw a lot of power. what gauge wire should i run?
If this is the Kef Model that you are considering then it's supposed to be an 8 Ohm speaker so you don't need a lot of power to drive them. Speakers that are 4 Ohms certainly require more power than an 8 Ohm speaker.
Is this the KEF you are considering?
REFERENCE 201/2
