This is my first time, so be gentle...
I have put together a resonable HT system, but have been missing a subwoofer, and funds are severely limited. However, I have two guitar amps siting around and decided to audition them for the part. When each was connected to the subwoofer out port of my receiver/amp, the main result was a loud hum. Thanks to some hints on this site and on a Yamaha site, I tried the three prong to two prong cheater adapter solution and it worked like a charm. Both amps work well now, although obviously the 300 watt amp is the preferred choice over the 15 watt cube amp (which still sounds not bad).
The question is, is there any problem anyone can see with this arrangement? WHat would be lost in doing this? Neither is a closed cabinet, but the sound output is not bad. Also, not being an actual powered subwoofer, it would seem to avoid the double filtering problem mentioned in the terrific Polk audio site (http://www.polkaudio.com/home/faqad/...cle=bassmanage).
So, is there anything I should be concerned about?
Many thanks for the previous hints and for any help you can give now!
