Quote Originally Posted by peep08
thanks! the site helped a bit but i found some of the concepts a bit overwhelming to understand fully. Just another question, if i were to run a headphone amp from the phones jack on my 5.1 receiver, would i be utilizing it to its full potential as opposed to running it directly from the source?
I'm really not qualified to answer your question with your type of setup.I only know that that a headphone amp is extremely benifical in driving the very best headphones you can buy.If you chose a so so headphone than chances are a headphone amp is really not necessary.However,you can go to headfi.com and do some more reasearch there.Hope this helps.
