Results 1 to 5 of 5
    Aug 2007
    Red face HELP with choosing SONY htib AUDIO SYSTEM
    Need help deciding on these two speaker sets. I have a coupon to sonystyle so it kinda has to be one or the other. I want one that will be the best for music.
    DAV-HDX500/i
    BRAVIAŽ Theater System 499$
    ---------------OR---------------
    HT-DDW995
    Component Home Theater System 399$
    Mar 2003
    halifax,nova scotia,canada
    Hello and welcome
    I am afraid that at that level there will be little or no difference between them.Listen to each, if possible using familiar music and see if one sounds better to you.Look for the features you are looking for as well.
    bill
    Speakers-Jm Labs
    Pre-amp-Sim Audio P-5.3 SE
    dac= sim audio moon 300d
    Amp-Sim Audio Moon I-3
    Display-Toshiba CRT
    Sacd-Cambridge Audio
    Remote-- Harmony 1100
    Power-- Monster
    Oct 2006
    Go for the one that sucks the least...which might be a toughie.
    You sound like you got the same deal a friend of mine got, he got a sony HTIB
    because his wife had worked at a grocery store for 20 years.
    He gave back the yamaha I had given him, " too complicated",
    liked his sony HTIB for awhile, then the speakers started giving out because he played
    it too loud trying to get vollume out of it.
    He's not very happy with it...
    His and Her Room! westcott's Avatar
    Houston Texas
    Quote Originally Posted by itsadamlikewhoa
    DAV-HDX500/i
    HT-DDW995
    As others have suggested, sometimes a deal really is not a deal if in the end you are still stuck with a less than ideal product. I could think of several ways to make your $500 sound a lot better.
