Quote Originally Posted by markw View Post
If you're talking two channel audio, then you should be fine using that digital optical link.
If you're talking digital multi-channel, then you are most likely out of luck.
not sure if it's two channel audio or multi channel?? we will mostly be plugging in "iphone for music, laptop for netflix, and xbox for gaming"
those are 2 channel audio???
as for dvd player/blueray, i guess they are not? right? so i can unplug the audio from tv to receiver and plug from blueray player straight to the receiver.
