They are very much like Klipsch. It's all about high SPLs. Having said that, even Gene Czerwinski acknowledges that static cable tests are irrelevant. Look here. Guys like Roger Russel have no clue whatsoever with their "It all sounds the same provided the resistance is low enough" mantra.
Why are you mentioning cables?
I'm personally not a proponent of expensive cables because I don't believe the difference between cables (in a 'normal' system) are great enough to justify the expense, especially when other components of the system make a far greater sonic difference, including speakers and room acoustics. If one wishes to extract every last ounce of music out of his expensive system, then why not...
I feel however, that most wild claims concerning cables are just that, wild claims. No 'night and day' difference.
I did hear however a 'night and day' difference a couple years back, when a salesman swapped speaker stands as I was auditioning a speaker. That was an eye opener.
Back to the speakers. I feel Klipsch is in a different league than CW, but I could be wrong.
