Quote Originally Posted by progfan
N. Absentia said:
"I bought Pink Floyd's Dark Side Of The Moon SACD, and even though I can only listen to the hybrid part of it on a standard CD player it sounds AMAZING!"
I've noticed this with Nektar's "Journey to the Centre of the Eye" as well. I don't have a SACD player, but when I play the CD using Pro Logic II-or even just straight stereo-it sounds incredible. The panning effects are great and it's one of the most dramatic CD remasters I've ever heard. For those who may have heard Nektar's original back catalog on CD, you know what I'm talking about
Don't know if this is the case for 'Journey' but for 'Remember the Future', the two-track mix comes from the the original 'matrixed' quadraphonic (SQ) master tape (four channels matrixed into two), which decodes fairly well using Dolby Pro Logic II (and presumably even better if you have a quad decoder).
The new surround mix is also derived from the quad mix, this time decoded and with a new 'center' channel synthesized.
