Results 1 to 25 of 48
    SF Bay Area
    It's this kinda stuff that makes discussing which is a "better" format or recording useless. Unless all is equal, there is no valid comparison.
    ...and Pink Floyd laughs all the way to the bank...
    You're so right about that. The most laughable part of these format debates is that NOBODY, aside a professional recording engineer, has access to the master source material that you would need to conduct a proper and equitable listening test. If you really want to test the SACD format versus CD, you'd have to have something recorded in DSD and PCM simultaneously, and then comparably mixed and mastered. As far as I know, no source out there is available for hobbyists like us that allows for this kind of comparable evaluation. Everything is either an analog, PCM, or DSD source and then transferred and/or converted into the playback format. If you're doing a true test of the format itself, you have to eliminate the other potential variables including the format conversions, and nothing I've seen even comes close to meeting this kind of standard.
    With Dark Side of the Moon, keep in mind that for that 30th anniversary hybrid disc a BRAND NEW two-channel master tape got created with the involvement of the band members and David Guthrie (who engineered several of Floyd's later albums; Alan Parsons, the original recording engineer, was not involved). This isn't even a format-related change, this is a completely different master source since they are not using the original two-track master tape that was used in the 1973 release and subsequent rereleased and remastered editions. They had an opportunity to do this because in order to create a 5.1 mix, the mixing engineer has to go all the way back to the multitrack session tapes (not just the "original master tape") and generate a completely new mixdown. This affords the opportunity to do the mixdowns without the degradations that would have occurred using the kinds of 1973-vintage analog tape machines that generated the original mix. From what I understand, the new hybrid DSOTM also made some changes in how certain sounds got mixed in (levels, imaging cues, etc.), so the end result is not necessarily comparable.
    Improving upon the original CD issue would not be that difficult. In my comparisons with the Mobile Fidelity half-speed mastered LP version, it wasn't even close. The low level linearity of the CD was flawed and almost had a "fuzzy" sound, whereas the LP sounded much cleaner especially during the low level passages. Almost makes me wonder what generation master tape Capitol/EMI was using for that transfer, because the LP actually sounded quieter in my A/B comparisons.
    Dec 2002
    Anyone can make recordings using a variety of modern low cost high quality recording devices available for the PC. A 24/96 khz A/D D/A breakout box of high quality can be had for just a few hundred dollars. Investiment of 100 in a high quality Rolls blanced line preamp, and you can rent a high quality microphone if you such a rental store is in your area. You can purchase or make a high quality microphone. I don't know how a consumer could make DSD recordings.
    Actually, since this entire debate revolves around the transparency of RBCD...I and I bet most other people that are skeptical would accept much more practical test.
    -Use the anologe output of the DSD or DVD/A, etc. and feed to a high quality professional 44.1khz PCM A-D-A. Compare the straight DSD converted signal to the A-D-Aed signal. If a difference is audible on a confirmed properly operating ADA with confirmed measurements, a valid scrutinized test methodology and tested amps/speakers that do not induce specific distortion themselves with the different bandwidths; then I(and i bet most others) would accept this as a valid test. If the properly operating/functioning A-D-A imposes a degradation in audibility, then the RBCD process may be inadequate -- at least that is the way I would see it.
    -Chris
    Suspended markw's Avatar
    I gave up on DSOTM several generations ago.
    First, I started with the original vinyl pressing when it first came out. Musicaly and sonicly It was a revelation in it's day but, then again, my memories of those daze is kind of smokey.
    Then, along came the Mo Fi vinyl. Now, that I liked! Even without the smokey haze it was a definite improvement over the original vinyl. Of course, the original was well played by that time. Even on the Miracord 50H/ADC XLM combo, you could tell it was well played.
    Then CD hit. I picked up the original CD reissue. Played it twice...
    Finally, Mo Fi did their Gold CD. Got that. Quite an improvment over the first CD but I still prefer the Mo Fi vinyl, which is played on a NAD 533/Goldring 1042 combo these days.
    I don't see a need to enrich these boys any more than I already have. I've already bought the same music four times... Maybe if I go multi channel but, even then, I dunno...
    SF Bay Area
    Quote Originally Posted by WmAx
    And I presume that you've actually done all this before? "A few hundred dollars" will buy me a decent universal player, and given a choice between that and a PC sound card, I'd rather go with something that will actually add to my norma listening enjoyment. If you can't make a DSD recording, then you have no basis for evaluating the actual format, because all other methods require a conversion from PCM or analog and therefore introduce other causal variables into the recording/playback chain.
    My point is that no truly comparable comparison discs are available to consumers, so any comparisons based on the what's most readily available to consumers will have any number of known and unknown variables associated with it.
    -Chris
    Again, you're not eliminating the signal conversion of the original source. If you want to isolate format/bandwidth as the causal variables, then you have to make sure that both sources are optimal.
    And if you're talking about a "practical" test, I hardly regard the need to acquire a "high quality professional 44.1 PCM A/D/A" converter as practical.
    Dec 2002
    That's a given. But you are the one that claimed only a professional sound engineer had to access to any suitable equipment. That may be laregely true for DSD, but not hi res PCM.
    I will address this in the proceding quote/response....
    It seems you missed the point. Digital sampling theory and known perceptual limits associated with the capabilities, confined to 44.1khz sample rate PCM, suggest that a properly operating A-D-A chain will take any signal that is audible, convert to digital, back to analog with no perceptible difference. If the ADA creates a percievable(in a proper blind test, protocol, scrutinized) difference then the ADA chain is not optimal. You have to convert the DSD to analogue to HEAR it. Take this analogue stream and feed it to the ADA......
    Since the DSD is supposed to be so good according to many, then surely the ADA will make an audible difference, eh? This would prove that 44.1 is not optimal for playback, if adible degradation occurs in the process. If no audible degradation occurs, then why? The answer is obvious.
    -Chris
    Chester County, PA
    Woochifer noted what is probably most important when comparing the DSOTM SACD/CD package with other DSOTM issues...it used different master tapes than ever before which could explain some of the difference you're hearing.
    As far as true comparisons for SACD vs. CD, PCM vs. DSD, had anyone checked out the new Musical Fidelity Hybrid SACD produced by John Atkinson, K622??
    It's a first of it's kind in that on the SACD layer tracks 1-3 are pure DSD and tracks 4-6 are the same tracks recorded with analog equipment and converted to DSD (similar to many of the SACD reissues).
    On the CD layer, tracks 1-3 are recorded with DSD and downsampled to PCM. Tracks 4-6 are recorded with analog equipment again and converted to PCM.
    They've even released it on 180g vinyl. More info can be found at the Stereophile website. If only they'd done a DVD-A version...
    Bill
    SF Bay Area
    And you're the one who claims that it's easy to do these kinds of comparisons, yet you're expecting a hobbyist to acquire professional level equipment. I assume that you've tried this for yourself? And the inquiry had to do with SACD, and the only way to properly compare that with high res PCM and downconverted PCM is to use original master sources that have been simultaneously encoded into both DSD and PCM. To my knowledge, no such sources are available to end users.
    -Chris
    Your statements are theoretical, and since you're so into proposing practical approaches for testing the theory, I'm simply noting that your approach still leaves variables unaccounted for. If you use a DSD master source and convert it to 44.1/16, then you're introducing a new variable into the chain. If you use a PCM or analog source, how are you going to get it into the SACD format if the tools aren't available to consumers?
    Dec 2002
    I did not claim it was easy to do the actual tests(a proper perceptual test that will survive peer review is anything but easy). I was pointing out that some of the equipment(hi res pcm in this case) is not nescarrily an out of reach item. I am not a recording engineer, yet I have such equipment that could be used to do hi-res PCM recordings accurately --- my use though is for acoustics analysis/measurement in relation to loudspeaker design---not recording music.
    This is true -- I lost track of the specific scope of the original poster.
    The issue is if 44.1 can retain the audibly relevant information that SACD can retain. THis does not entail converiting PCM to SACD, since SACD is the one that is being claimed as superior(not by you, but a general claim that is common and the premise of this conversation form my perspective). If a PCM 44.1 A-D-A process does not produce audibly decreased audio quality confirmable with controlled testing, then the SACD format is not audibly better. How SACD be audibly superior if a 44.1khz ADA process does not cause audible degradation?
    -Chris
    Jul 2002
    PC based recording has its problems, but also has its place. I would not use PC based recording on classical or Jazz music. You have to have a PC that is specially made for audio work as it must have the processing power, and VERY well shielded analog and digital stages. This is not cheap, and sometimes takes several processors daisey chained together to accomplish this goal. The sonic quality of PC based audio mixing and editing software is all over the place, and the plugin's are often very noisy. The Rolls microphone preamp is a noisy product. I wouldn't dare use on a 24/96khz recording(iunless it was a recording of limited dynamic range which would make using 24/96khz unncessary except to archive), and I certainly would NOT use it with a high quality microphone.
    -Chris
    I am sorry Chris, but I would prefer the test that Wooch proposes. Straight feeds from both a DSD decoder, and from the A/D-D-A stages of the 44.1khz. When it comes to getting signal transparency, less is more. The fewer times you convert from analog to digital and the reverse, the better off you are. At some point in the test you propose, the quality of the conversion is more of the focus rather than the formats themself
    Yet but you ask audio angineers to do this on the clients dime just to validate a point for you. Hmmmm.....
    If you talking garage/basement recording, you are correct. In those conditions there is no need for 24/96khz except for archiving. If you are talking about a high quality recording of something on the lines of jazz or classical music, that kind of equipment is still out of reach of most consumers. I doesn't cost much money to get into high rez, but it does cost money to do it well.
    Now here is were I get confused. How do you test the QUALITY of the audio? Isn't the idea of sound quality purely subjective? What sounds good enough to you, may not to me(in this case redbook CD). You hear differently than I do, somebody else hears differently than you. What if nobody in the testing panel can hear any higher than 13khz, and I can hear up to 18khz? What if many in the panel had mismatch frequency response in each ear? How would that represent what I hear if I don't, or mine is not as acute? There are certain key things to listen for when comparing redbook to high rez, what if I knew what they were, and nobody else did? I think a test can be conducted to reveal differences(to a certain degree), but sound QAULITY is too subjective to be made objective enough to formally test, and be submitted for peer review.
    Two things I would like to clear up. I never said it was FACT that SACD sounds better than redbook. I said IMO it does. Secondly, you can stop saying that I said the higher bandwidth is the reason that high rez sounds better than RBCD. I never said that was the reason, I said it was one of the beliefs that have been expoused.
    There is a problem with this theory. In reality its not possible. This would mean that the delta sigma modulator(s), decimation filter, interpolation filter, and the analog low pass filter would have to operate perfectly, with absolutely no loss or audible distortion whatsoever. That just doesn't happen in real life. None of these stages operate with perfect transparency. And since components come at different price points, the best of these filters cannot be put in every player. Every conversion process degrades the signal to a degree(audible or not).
    Sir Terrence
    Oppo BDP-103D
    9 Onkyo M-5099 power amp
    9 Onkyo M-510 power amp
    9 Onkyo M-508 power amp
    6 custom CAL amps for subs
    THX Style Baffle wall
    Dec 2002
    This is why a specified a break-out box type AD, DA, to avoid noise that may be induced on internal sound cards. I recognize this problem.
    I was not suggesting full scale music production. I was suggesting using the device for 2 channel recording/playback use.
    Well I have to ask, noisy compred to what? It's seems to be considered one of the quietest units for the price(under $100) on the market on the newsgroups according to Arny Kreugar, and thus extremely popular for measurement systems, etc.. Though I don't personally make any claim to it's 'noise' level one way or the other. I mean the Rolls MP13. It's probably not as quiet as a very high quality professional device but at a point the noise floor is only usefully low. It is not as if a non professional is likely to have access to an isolated sound room that is structurally and acoustically shielded that has a low noise floor. Though, I suppose some very die-hard hobbyists may have built such a thing in their basement. But, I don't knw the actual noise floor of the MP13 product. I can not trust a manufacturer published specification -- so that spec does not count. It's definately not worth measuring the unit myself just to get a precise value for this conversation. But again, if I did, what would I compare these numbers too? You would need an objective 3rd party measurement of the units you wished to compare.
    Well, I would prefer that test too if properly created....but the issue in this case was practicality of testing transparency without having a DSD recording system.
    Because I asked for substantiation at that point. I asked for reference to a valid perceptual test that could establish if hi-resolution audio was any better for playback quality audibly in response to your statements that were made as absolute claims/facts. But maybe you did not mean too state in this manner....refer to [1]
    Well, quality can be established for statistical value. I actually did not mean to use teh word quality. I meant to refer to difference. My error.
    Most valiated listening tests to this point have used 15 or more trained listeners, usually audio experts, etc that have varying listening abilities in order to aquire more meaningful restults.
    In validated listening tests, the test subjects are given ample time to review the test samples under sighted conditions in order to become familiar.
    I did not mean to bring up quality. However, quality can be determined for a statistical value. CRC in coordination with Mirage labs performed a huge study a few years back to determine the preferred polar resonse and frequency response of loudspeakers under controlled test conditions. The overwhelming majority preferred a single example. True this does not cover every single person, but an overall quality could be established. But, as I stated earlier I did not itend to refer to 'quality'.
    [1]
    Let's examine some quotes from the thread you refer:
    SACD vs. CD - Unfair competition?
    Sir Terrence: "The true benefit of using a higher sampling rate comes from more in band sampling of the voltage of analog waveform. The more times you sample the waveform, the more precise the imaging, the better the tonal quality, and the higher the resolution of the audible signal."
    Sire Terrence: "Does the sample rate make a difference in sould quality? Definately. Why? I know it improves imaging, and the sound is cleaner and more distinct to the ear, but otherwise I don't know. Does bitrate matter? Only in recording and post production. I'll let the scientist figure the other crap out"
    Those are some pretty solid statements, with no IMO or too my perception, etc. contained. In this search I found a reference that you did say at one point everything you sated was 'IMO':
    Terrence: "I never stated anything as FACT(that's what you gathered), its is a broad based opinion. While you are quick to dimiss it, I am not."
    If this is a standing qualifiacation that is to apply to everything you stated in regards to audbility of hi-res audio, then it looks like most of that 400+ post thread was teh result of statement errors. I take things quite literal, when a new statement is made without the qualification in this exampel of IMO, it is taken as a fact/claim by me. If you had been careful to state all of your opinions of hi-rez as opinions; of course I would have had no argument. Everyone is entitled to which ever opinion they desire.
    Huh? I don't remember referrint to you in this thread whatsoever until this very reply. Where did this come from?
    The frequency response, phase response, jitter and distortion levels present in hi quality moderan A-D-A process are below known human auditory thresholds for these parameters as determined by peer reviwed percetual tests. How will it have an audible effect? Specifically which parameter is within human thresholds of audibility?
    -Chris
    Jul 2002
    Your problem does not stop at the sound card. Is my hard drive large enough to handle my needs? Do I have the right interfaces to handle data transfer and processing? How much of my CPU is used during processing, and is there enough to multi-task? You will need two monitors because audio application take up alot of screen space, and you need one as a track monitor, and the other as your mixer. You will need to install a dual video card system(not cheap) to handle your monitoring system. You need a good power supply, and a good fan system to cool it. I could go on and on and this is just to do basic recording. In the end it is not so cheap to do PC based recording. You cannot just use any PC for the task, and it certainly cannot be a cheap one at that.
    See my response above
    Compared to other preamps in the $100 and below catagory. In all honesty, that is not saying very much, because all of the preamps at this price point are pretty noisy.
    If this thing is used in measurement systems, I would highly doubt the accuracy of those measurements unless this preamps noise levels are taken into consideration.
    You don't even have to do a comparison with anything. I was asked to clean up a recording of a cover band's performance to use as a demo. The vocals were recorded with this preamps in the signal chain. As long as the levels stayed up, no problem. The preamps noise was hidden by the program material. Once the levels dropped, the preamps gain produced a very noticeable hiss. The hiss was so objectionable, that the bands leader decided to ditch the tracks it was the worse on. My second encounter with this preamp came in the form of a gospel video I was doing the sound on. Once again the Rolls was on the vocal microphone. This time the recording engineer was gain riding, and the hiss rose and fell with the level. For doing live sound and no recording, the preamp would probably be okay. But for recordings, you get what you pay for IMO.
    In the absence of a DSD recording system, I would use source to 176.4 or 88.2khz, and source to 44.1khz. No downsampling, no downconversion, no dither, no processing in the chain whatsoever.
    You can't really substantiate that point. Once again sound quality is subjective, not objective. As long as individual have varying tastes, and different perceptions of what sounds good, then there is no way to test sound quality. What sounds good to me may not sound good to you, and visa versa. So from that perspective, and to a individual with experience in both high rez and redbook sound, it might be a fact that high rez sounds better to them. And if they have had enough experience, and continue to hear the same things then their opinion does become absolute. So within this context, absolute claims/facts are personal, and allowed can be expoused as such.
    As far as stating that SACD sounds better, to me its a fact that it sounds better than redbook CD. Prove it, impossible! Without 15 people with the exact same ears, head and brain as I do, this would be impossible. And 15 people without the same ears, head and brains cannot speak for me.
    Differences can be tested, but quality cannot. Too many variables amoung the panel.
    This may be okay if you are trying to study objective qualities, but sound quality is not one of them. Varying listening abilities in a sound quality test would produce varying results and would tell you nothing. Even you could tell differences in this panel, they still would have a terrible time trying to ascertain which is better.
    Since I have participated in several Dts vs DD DBT I am VERY familiar with this.
    This doesn't really address "quality", it just addresses what sounds more like a live event if we are talking about the same listening test.
    [1]
    I do believe you jumped the gun just a bit. I cannot speak for the masses, just like they cannot speak for me. So no statement I make here can has to be my opinion only, because as we have seen here taste vary from person to person. However, when my opinions mirror the opinions of quite a few other(especially some very trained ears) I am going to take pause and listen. Do I need DBT, yes for my clients, but not necessarily for myself. When I hear a improvement, I relish in it. If I wanted to find out why, then I would leave that to testing. But if I went to DBT for everything under the sun, that would me I have no faith in my ears, and should probably get out of the business I am in.
    This is for your general understanding.
    -Chris[/QUOTE]
    This statement is meaningless because they don't put high quality parts in every CD or DVD player, or in every digital recorder. The quality of the A/D-D/A is all based on price points. So you are going to get varying and subtle degrees of distortion and any point in that chain whether it comes from the recording equipment, or the playback. Stanley Blackman tested 23 high end and budget CD and DVD players, and found all of them aliasing in varying degrees of amplitude. The anti-aliasing filters were letting small amounts of high frequency information leak through to the converters. Some of the distortions were audible(on the budget CD players) and some were not. I have used digital recorders with very questionable A/D-D/A converters, and the results left me cold. I have used DAW who's connections caused very audible jitter. So to make a blanket statement without testing every component every made, ones made now, and the one that will be made in the future, is insane, and IMO misinformation. Digital is no perfect ride.
    The Nyquist theorum is flawless and has never been challenged. But Nyquist never said it would be easy to implement. That is the weak point IMO
    Sir Terrence
    Oppo BDP-103D
    Dec 2002
    1st, one does not need two monitors to do basic recording. 2nd, most of the things you are mentioning here aer basics that I see no reason to cover in this thread. Hard drive size? Jeez. Well I suppose someone could be stupid enough to not realize they have to have disk space to record onto.
    Do you ahve third party measurements of the preamp? 'pretty' noisy does not tell me anything.
    Again, what is your definition of noisy? What -db value do you cnsider quiet?
    How do I know that it was used properly or what otehr possible noisy equipment was in teh chain or that their mic was not noisy?
    This is a testimonial and does not establish anything. You realize testimonials are not worth much, right?
    Also, this is a tangent that is just not the main point of the conversation. I'm going to shorten these replies as much as possible from this point. Though it's tough to cut much out considering the original size.
    Good.
    Ok. So, you also can not substantiat what level of THD is audible among a statistically relefvant test group, or IMD or SPL detection thresholds, or etc.. Yeah, sure. Keep belieiving what you like. I know you stated previously you don't believe in audiophile snake-oil stuff, but this is one of their pinnacles of belief and it is not rational perspective.
    If you just change that to 'percieved by them as better', I'll be glad to agree. Otherwise no dice.
    I don't have to prove anything; it's you making the claim. If you can not back it up, why would I or anyone else belileve it as a fact?
    Sorry, but large sample groups have established various 'qualities' previously, such as teh NRC - Mirage study on speaker response issues.
    I am referring to the NRC/mirage labs test that Ian Paisley headed, that analysed 2000 people in DBT speaker testing, from a pool of over 300 speakers, with smoething like 95% of the people preferred the same small group of similar response speakers(that all had the same basis frequency and polar response as compared to all of the others). I can not recollect the specific reference paper at the moment. It demonstrated that 'a' specific quality can be determined as 'better' by a majority of people. I never claimed that it covers absolutely 'everyone' if that's what you inferred.
    Sure you can. I can state with reasonable certainty that no one can identify 0.05% harmonic distortion. No one has ever proven that they could. Why should I believe that their is someone that is likely to hear it? The same goes for anything else that has been tested for properly. In these cases such as visual and audio perception, y ou can research the subject into the depths of physiological basics that actually dictate perception limits among humans based on the construction of the parts. Tell me what person can see gamma rays? What person can hear 50kHz? It's just beyond the physiological limits.
    Good for you. It's probably the most efficient method for your situation. I don't doubt that. However, don't try to force your unproven opinions as facts on others. If you dont' mean to do that, word your statements more carefully and specify it's your perception or opinion. IS this do difficult?
    Frankly, I'm not responsible for 'poor design examples' that can not remain at suitable distortion levels. It's not rocket science, and high quality ADA chips from TI(burr brown) are cheap and mass produced today. Their are standing examples on how to design the circuits to remain free of audible distortions. I can not think of a single component internally th tis prohvibitive in cost to produce transparent device at low prices -- not today. BUt I've noticed what appeared to be extremely poor design of any given product you can concieve -- so it's not beyond possiblity that a very low price CD player from a no name brand company would not be 'transparent'.
    What levels? Proven audible by knowln correlation to JNDs or by DBT testing?
    Must be some poor design work, extensive documentation exists on proper anti-alias filter topology construction as well as perceptual studies on what filter slopes/types are not deterimental to audible sound quality.
    NOt suprising. However, I would still require the detaile measurements and/or the DBT results to confirm the claims on any specific model. I would actually love to read this article. Do you have the reference for this meaurement set? link? magazine issue number? etc.? It would be appreciated.
    Tell me, at what point did i ever state that EVERY AD or DA ever made would be below audible thresholds? I never did. Where does this come from?
    -Chris
    Jul 2002
    Have you ever done basic recording off a computer system? So you are making this statement from first hand experience I take it. Probably not. If you have, then you would understand that the graphics take up alot of screen area. So it is practically impossible to move faders and monitor levels at the same time.
    You would be surprised how many people use computer based DAW and have run out of disk space. So it is kind of naive of you to think everyone is well schooled on the use of computer based DAW. You have a penchant for glossing over detail, maybe its a good thing you are not a audio engineer.
    Didn't need 3rd party measurements to tell me this component was noisy. You could plainly hear it. I think you would have to be pretty simple to have to ask someone else to confirm something that was that obvious. If you are looking for a specific figure, well that would be variable. Depends highly on how much gain is used.
    I didn't know you have trouble with the english language. Noisy= a sound, or sounds that is loud and unpleasant according to websters.
    See above for my defination of noisy. What I consider quiet is something that cannot be heard distinctly. I do not look for numbers like you do, that is irrelevant in a recording situation. What is important is that no extraneous noise should enter your mix.
    You may not know anything, but I was with the live recording engineer, and he knew for a FACT it was the preamp. When it was bypassed out of the system, the noise disappeared. It doesn't take rocket science to figure out were the problem was.
    Chris for YOUR benefit and convience, you can call it whatever you desire to make it easier for you to dismiss. But your recommendation of this component was just as worthless!!
    Once again, if it makes it easier for you to dismiss, call it whatever you desire.
    Good.
    I did not say that did you really read what I said???? I said sound QUALITY CANNOT BE DBT TESTED. Everyone has their own idea of what sounds good, so their is no objective means to determine something as subjective as that. As far as the other perimeters you mention, I never said that DBT was not useful to determine any detection levels. Your response to this is overly emotional and out of context
    Whether it is no dice to you is irrelevant. If one believes that something sounds better than something else, that is a fact to them. Maybe not to a naysayer like yourself, but who cares, you don't run the world.
    Who said this has to be about you? You seem to believe that someone has to prove something to you. Chris the world doesn't revolve around you and your demands to prove everything under the sun. I suppose you will be asking to prove that I went to the restroom 2 minutes ago!
    That study was not designed to be objective, it was subjective in nature. It results were based on listener PREFERENCES(a subjective perimeter). They used DBT to obtain a sujective result.
    They used 3000 people and it was based on a PREFERENCE, not something like the detection threshold of the A/D-D/A stages in a given digital component. The panel was asked to grade speakers based on their sound qualities(subjective). Those speakers that received a good grade were group together, measured, and the results of the measurement provided the werewithall to produce a good sounding speaker. What they were looking for was opinions(something you completely reject) and not some antiseptic result that you constantly pursue. They did exactly what was done at Surround 2003. I A-B identical musical passages DB, and was asked which I though(subjective) sounded better. I did the test 4 times, and all four times I choose SACD over redbook. This test was given to 122 people over two days. On the last day the results were told to us. 95 people chose SACD, and the remainder chose redbook. Using the NRC model the results speak for themselves. All of this is purely subjective.
    The only thing that you can say with any certainty is that you have not tested 6 billion people, and that conclusion is based on studies involving a tiny fraction of that amount. Until you have tested everyone on this planet, your certainty is tenative and incomplete.
    Because not everyone in the world has been tested. And that is based on objective criteria, not something subjective as sound quality.
    This is mudding the waters(you really like to do this) and has nothing to do with sound quality or any other subjective issue.
    No one is forcing anything on you(another overly emotional response), you have a right to accept or reject any opinion. Perhaps rather than telling me how to word my posts, you should check your interpretation skills. Perhaps in your rush to oppose me you interepreted the meaning, and the spirit of my post incorrectly. Especially when it was already stated as my opinion. This is what happens when you gloss over details like you have done in so many of your responses.
    Your thinking is VERY compartimentalized. Burr Brown makes many different types of chips all with varying degrees of quality to meet certain price points. Not every computer can use pentium chips and meet certain price points. Some have to use Celerons(which is not that great of a performer) to meet that price point. With price points of electronics being pushed down at every hand, Burr Brown chips cannot be used with all DVD or CD players. By the way, cheap is relative just like good sound quality.
    Yes, the standing examples usually have the best parts to begin with, implemented in the most logical, and simplistic way. These products are usually high end products that do not have a price point. That is not representative of the masses. If its so easy to do, then why isn't it done in every DVD and CD player on the market, budget and high end? It apparently isn't as easy as you are trying to tell us, or it would be done.
    Its not just low price players from a no name brand company, but apparently mid and high end players from major brand names.
    I know based on measurements, but I am not entirely sure if it was DBT or JND.
    Yes but does this documentation teach you how to apply this topology in a wide variety of players, that cover varying price points? I do not think so.
    This paper was passed around at Surround 2003. He was submitting it to AES, but wanted a 2nd party to test the same players to verify his results. I am sure you will see it once it is published.
    -Chris
    You expouse theory like the signal and processing chain is transparent always. You never take into consideration real world realities in regards to what is practical, and cost effective. Its just pure theory with you. That is not rational or particularly realistic. You make alot of assumptions based on theory that in the field are cumbersome, inefficient, time consuming, not to mention labor intensive and unnecesary. This is what relying on theory(without any experience)alone will get you. In the field everything that is possible to do may not always yield good sonic results. Experience teaches you that.
    Sir Terrence
    Oppo BDP-103D
    Aug 2004
    [QUOTE=Woochifer]You're so right about that. The most laughable part of these format debates is that NOBODY, aside a professional recording engineer, has access to the master source material that you would need to conduct a proper and equitable listening test. If you really want to test the SACD format versus CD, you'd have to have something recorded in DSD and PCM simultaneously, and then comparably mixed and mastered. As far as I know, no source out there is available for hobbyists like us that allows for this kind of comparable evaluation. Everything is either an analog, PCM, or DSD source and then transferred and/or converted into the playback format. If you're doing a true test of the format itself, you have to eliminate the other potential variables including the format conversions, and nothing I've seen even comes close to meeting this kind of standard.
    i agree compeltely.
    Actually, I don''t think they created a new 2-channel mix, at least not according to any interviews with Guthrie et al that I've read. What's your source for this?
    [QUOTE]Improving upon the original CD issue would not be that difficult. In my comparisons with the Mobile Fidelity half-speed mastered LP version, it wasn't even close. The low level linearity of the CD was flawed and almost had a "fuzzy" sound, whereas the LP sounded much cleaner especially during the low level passages.
    What is 'low level linearity'? Linear as compared to what? The master tape?
    That might be acclimation to LP noise -- or the CD layer of the SACD brought up the tape noise due to compression.
  1. SACD 2 Channel Output - I'm Confused...
    By Sammy EX in forum General Audio
    Last Post: 08-18-2004, 02:07 PM
  2. Replies: 12
    Last Post: 07-05-2004, 03:14 PM
  3. Simple question about my amp amp and pre-amp
    By kexodusc in forum Amps/Preamps
    Last Post: 03-26-2004, 06:05 PM
  4. simple question about speakers-amp fit
    By davidbolan in forum Speakers
    Last Post: 02-15-2004, 05:28 AM
  5. Question regarding SACD connections
    By Tyler in forum General Audio
    Last Post: 01-29-2004, 05:03 PM
