Hello again guys .
I just installed the RP1 with the Denon 710AE and connected my Beyers Dt880
I must say that i run into some problems and here comes your precious knowledge .
I have to list what i experienced and maybe you can answer shortly what i have done wrong.
I must clarify that i have a SECOND hand RP1 perfromance pack ( previous owner only used it a few times ) in case that will help.
and FIRST of ALL excuse me for stupid questions/or the non expert vocabulary i use below
1) When i put the vinyl on the platter and i am picking up the tone arm to put it on the side of the vinyl and push the metal thing down so the cartridge can touch the vinyl , the tone arm doesnt actually stay stable but leans continuously to the right (the cartridge acctually misses the vinyl and comes outside of the platter) of the vinyl ? Is this normal ? what have i done wrong ?
2) Although in the instructions Rega tells that the TT does not need a signal grounding (the tonearm cable doesnt have a grounding cable) when i put my headphones and turn on the Denon i keep hearing a continuous buzzing noise ,with a clicking noise every 2 seconds ,and when i touch the tone arm with my hand the buzzing noise and the clicking noise gets louder. Whats wrong with that . Is it indeed the grounding problem or anything else? How should i fix it if the tonearm cable doesnt include a grounding cable, sould i buy a new one ?
3) When i have turned on the Denon and pick up the tone arm and move it in the air , i keep hearing hissing/crackling noise . Is this normal ? I mean i havent even put it on the vinyl and keep hearing that distinct noise in my headphones . Is it because i purchased a second hand RP1 and the cartrige (performance pack so it has a Rega Bias 2 cartridge ) is somehow broken or has picked up dust or another reason ?
4)I put on some Beatles (which i bought as a test the TT) second hand 12 $ and it was not in such a good state ( but no scratches , just dust) . I put it on and i must say that i didnt enjoy at all the sound coming in from my Beyers. Lots of hiss/crackle noise and i actually observed the cartridge gather some dust/little fibers on the needle. And i must say that the noise wasnt so good compared with my FLAC MFSL Beatles box set (downloaded) sound. I know these two cannot compare actually because you would say that i should buy the MFSL box set and compare it with my FLAC files but how can i reduce the hiss/crackle noise coming in from my vinyl ( or cartridge , my 3d point above) . ( probably stupid question but any insight would be grately appreciated )
5th) I put on my brand new never before touched limited edition LP of Elektra Records compilation and i must say that i was astonished by the sound. Really really great sound BUT the hiss/crackle when the song ended could be heard. So 2nd stupid question , can this be eliminated or is this totally normal ? Is it again my cartridge fault ?
Thats all for now and i hope to hear from you soon . Thank you very much in advance and sorry for the vocabulary i use and and possibly silly questions
