Quote Originally Posted by poneal
NOTE: the 6 RCA connections are for an analog connection to your recevier. You don't need to connect this since you are using digital/optical cable.
Although digital in nature and thereby similar to DD/DTS, SACD is an entirely different creature. While receivers can decode DD/DTS via a digital feed, no receiver at this time can decode SACD (or DVD-Audio for that matter) from a digital feed. All SACD (& DVD-Audio) decoding must be done within the player and fed, in analog format, to the receiver via those cumbersome 6 cables.
