Has it ever occurred to you that it wasn't that the JPS AC+ was so good but that the Kimber Palladian was so bad? How about trying 12 gage lamp cord and see if that changes anything?
To anyone who actually believes this dribble I offer the following advice; get some of the same wire you home is wired with, Romex or BX and make a cord out of that. Then hard wire it through a disconnect switch. There, for a few dollars worth of electrical hardware, you have beaten ANYTHING the marketing guys can come up with in the way of power cords, receptacles, and IEC connectors. And if you can find a tie in point a few feet close than the outlet you would have used, you have effectively eliminated the role any power cord would play even theoretically. But don't be surprised if it doesn't help one damned bit. It just won't. BTW, if the Soaring Audio amp works so much better with the JPS cord, why didin't they include it as part of the amp? Wouldn't the manufacurer of the amplifier know best which cord to use especially if "digital amplifiers" are so sensitive?
