Quote Originally Posted by cgibsong002
so an update after having the Energy's for a while now. They sound amazing, but I've got one problem. My one speaker occasionally cuts in and out. Not fully cutting out, but a bit of static (not sure how to describe it) as if there's a bad connection somewhere. I don't believe it's my receiver. I'm using the Sherwood and I had the same problem through both the A channel and B channel. Is there anything that could likely be the problem? Or could this be anything? Additionally, is it possible that the speaker wire could be getting interference? My wire runs right past a whole range of equipment from audio equipment, to guitar amps, to my computer. It's just odd that sometimes it'll constantly be cutting in and out, and then there's times when I can listen to a whole album and not notice it once.
IF its happining with one speaker, and not the other and on both the a channel and the b channel with the same speaker...then you have pinpointed it down. If it where me, I would open the speaker if I could, to look at the wiring to make sure it all looked ok. You could very well have a loose connection inside.
