You want to keep your speakers about ear level when you are in your listening position. Putting them high up is not a good idea. You might cure one problem but create another. You also don't want to spread them out so far that you sit close in to them. A general rule of thumb would be to make a triangle of you and the speakers with the sides, distance between speakers, and, you and speakers, being equal.
