Congrads, decent player at a great price. For cables on a budget and good performance I recommend Bluejeans cables http://www.bluejeanscable.com/ They will work great for your system.. There are better but cost is at least twice as much and may not do more for you until moving up into gear with more resolution. I hope you get what I mean, BJC are plenty good and the extra expense for better may not be realized.
Now that you have such a nice player have you thought about maybe a Cambridge or NAD integrated amp? Have you checked www.spearitsound.com ? If in your area to listen to you might want to check out Paradigm or B&W before making your final decision. Even if you get the HK & Polk with the 640 on the front end I think you will be pleased with what you've done for yourself. Happy for you.
