You really do not need to hear the raw DXD stream to appreciate the quality it has. 2L has done several recordings using this technology and has downconverted them(losslessly) to 24/192khz PCM for release on Blu ray. The discs can be purchased on Amazon.
http://www.amazon.com/2L-NORDIC-AUDI.../dp/B0025ZITT2
You can also find some of these recordings on SACD as well.
Hello Sir Terrance! If I may ask, is there a difference in DSD or DXD from SACD or DVD-Audio? I have a Pioneer DVD player which plays both hi-def formats. Thanks!
