Quote Originally Posted by phileserver39
Hello Sir Terrance! If I may ask, is there a difference in DSD or DXD from SACD or DVD-Audio? I have a Pioneer DVD player which plays both hi-def formats. Thanks!
DSD is the raw stream which is the basis for SACD. DXD is the highest recording resolution every acheived, and can be losslessly transferred to SACD and DVD-A. With DVD-A, you can only use two channels of 24/192khz, and 5.1 channels at 24/96khz. With DSD(and therefore SACD) you can use all 5.1 channels. With the Blu ray format you can use 5.1 channels of 24/192khz, and 7.1 channels of 24/96khz PCM audio.
The pioneer unfortunately turns the DSD stream into PCM so that bass management can be used. This degrades the audio a bit - which is audible when compared to a player that can process the raw DSD stream.
