Vance Dickason - Loudspeaker Design Cookbook
Ray Alden - Speaker Building 201...
David Weems - Designing/Building Speaker Systems.
I would start with the Alden and Weems books...if you can get through that, Dickason book is your next step. The Cookbook is the bible for DIY-ing...but it gets technical and some noobs have a hard time following it...the others take more time to explain the basics.
http://www.parts-express.com/wizards...CAT&srchCat=72
Yep, they're the classics. Start with them.
You might want some design software too. Athough they have some limitations, HT Audio's Bass Box Pro 6 and X-Over Pro 3 are elegant, easy to use programs.
