Loudspeaker design books
Printable View
  • 11-08-2009, 06:06 AM
    audio amateur
    This is one thing I want to get into as of this christmas break, so I'm thinking of putting this on my x-mas wish list. Currently I have two 4" drivers that I'd like to build an enclosure for and run full range with no x-over so it'd be good if the book covers a wide range of speaker designs. I'll probably start another thread with more specifics about the project nearer the time.
    Any suggestions of decent books?
  • 11-08-2009, 06:35 AM
    kexodusc
    Vance Dickason - Loudspeaker Design Cookbook
    Ray Alden - Speaker Building 201...
    David Weems - Designing/Building Speaker Systems.
    I would start with the Alden and Weems books...if you can get through that, Dickason book is your next step. The Cookbook is the bible for DIY-ing...but it gets technical and some noobs have a hard time following it...the others take more time to explain the basics.
    http://www.parts-express.com/wizards...CAT&srchCat=72
  • 11-08-2009, 12:33 PM
    Feanor
    Yep, they're the classics. Start with them.
    You might want some design software too. Athough they have some limitations, HT Audio's Bass Box Pro 6 and X-Over Pro 3 are elegant, easy to use programs.
  • 11-12-2009, 09:11 AM
    audio amateur
    Thanks a lot guys
