Page 2 of 2 FirstFirst 1 2
Results 26 to 27 of 27
  1. #26
    stuck on vintage dingus's Avatar
    Nov 2005
    Graham, WA
    the Squeezebox will also connect with a Cat5 cable ...
    AR MGC-1, AR C225 PS, M&K V-1B, Pioneer VSX 47TX, Oppo BDP-83, Squeezebox v3, Vortexbox Appliance.
  2. #27
    Forum Regular Corto Maltese's Avatar
    Sep 2007
    Mr Peabody - yes it is. Techonology is there, but manufacturing is not. Quality departments are staffed with general labour, trained to perform simple tasks what are there as a (not quite sufficient) support and not to control the production lines. And that is the case for every mass production, everywhere. Lemons after lemons...
    For home wireless, I'm using simple Linksys WRT54G for second year now. Wireless-G is on the market for a long time, they should have taken the bugs out by now, which means less lemons... I am quite happy - slow or fast, as long as it works... and file sharing between all of us (2PCs and 2 laptops) is OK, laser printer is in the grid as well - everything is OK for now. I am just waiting for this router to die, those things are designed not to last. I will try to find the exactly same, but new.
