Results 1 to 25 of 56
    Jul 2002
    There is no way you will be able to tell whether HDCD sounds superior to Redbook unless you have the original master, and you compare the unprocessed output with the processed output under DBT conditions.
    My experience has shown that a well mixed and mastered CD can should every bit as good as a HDCD.encoded one.
    If you begin with good recording practices, and sufficent bit and sample rate (I always work with 24/96khz as a start) there is no need for HDCD processing at all. IMO with the ability of higher bit and sampling rates that can be used, HDCD is a waste of time.
    But, rationally, as far as I undestand HDCD doesn't doesn't increase the sampling rate, but does increase the dynamic range from 16bit (65536 shades of loud) to 20 bit (1048576). I think TT said this should drop the noise floor. I don't know if a person could really distinguish all the finer shades of loud though.
    Actually it depends on the music. The difference between 16bit and 20bit is much more audible on highly dynamic music. You would be very surprised how sensitive the ear is to slight volume changes. Especially in the midrange.
    Sir Terrence
    Oppo BDP-103D
    9 Onkyo M-5099 power amp
    9 Onkyo M-510 power amp
    9 Onkyo M-508 power amp
    6 custom CAL amps for subs
    THX Style Baffle wall
    Jan 2006
    Rochester, NY
    I think that's the most important point that needs to be made. Repeatedly.
    SF Bay Area
    I think you nailed it! It's impossible to know what effect the HDCD processing has without a master source to compare it with. Problem with using HDCD-encoded discs to judge the value of the format is that there's no way to compare a HDCD-encoded version with a non-encoded version, unless that CD was previously released without the signal having gone through HDCD processing. And even with a re-release, other changes during the mastering process could have occurred and likely did because remastered CDs typically address problems that occurred with poorly done early transfers.
    Also, I read that the HDCD encoding can create distortion when the HDCD discs are played back through a non-HDCD CD player or processor. This further diminishes the comparability of using HDCD-encoded discs to identify any improvements that the format itself is responsible for.
    Yamaha RX-A1030
    Sony UBP-X800
    Sony ES SCD-C2000ES
    JVC HR-S3912U
    Directv HR44 and WVB
    Logitech Harmony 700
    iPhone 5s/iPad 3
    Linksys WES610
    Dec 2004
    Cal
    I'm not comparing it to a master,i'm comparing it to sounding good just like DTS which i like better then DD. Why? Because it sounds better to me.
    Look & Listen
