Results 1 to 2 of 2
    Jul 2004
    Fire, Insurance Replaceing my system need advice
    Hello everyone, my name is Johnathan.
    Ok so here is the story, my house burnt down and now I must replace my system.
    This is what I used to have,
    Sony Receiver amp (no tuner built in)
    Quartz Sony Tuner
    Sony Dual Dub tape decks
    Sony 5 Disc CD Player
    Sony Speaker's 5.1 100w Per Chan
    2 Front
    Center
    2 Rear
    Sub
    Now I had all Monster Cable Products (SPID/F, RCA, Sub Cable, Speaker Wire, Optical etc)
    Ok so lets get to my questions. I have about $2000 to spend on replacing my system itself, Plus replacement cost of all the wires and cables.
    Basically I donít need a CD Deck or Tape Deck. I only want to replace the receiver and speakers, sub, and cables.
    I have digital sound coming in from my laptop(apple) and Home PC through a M-Audio Firewire Audiophile, and my Turntables, Midi Keyboard etc.
    I was hoping that some of you here could direct me in a better direction then Monster for the cables I liked their sound quality but for the money I know there has to be better RCA SPID/F etc.(Yes I know Home-Depot 12AWGfor speaker wire) But I am not paying for this stuff and all my cables have to be replaced so if I donít spend the money I loose it.
    Also I could use some help with speakers and receiver choices I would like to stay with the 100w x5 or 100x 7 Chan in my budget and was looking at Sony to do this, speakers I have not even started to look at yet. I have around $2000 for speakers sub and receiver as I said above so any suggestions in this price range would be great.
    Thanks for your time,
    -Johnathan
    FL
    Various cables - $125
    Yamaha HTR-5760 - $399.99 delivered (authorized internet dealer)
    nOrh ceramic 4.0 video package - $575 ($500+ shipping assuming you decide to buy mine. They are the blue/silver color. New they go for $850 delivered. You'll either love or hate the looks.)
    SVS 25-31PC+ - $775 + shipping so look for it to be around $825ish delivered.
    Total - $1,925
    The above is a simple recommendation to get you started. Of course, a great deal depends upon your room size (L x W x H), especially with regards to the sub. You may need to spend more or it could be relatively inexpensive (around $450). Used gear can save you money. There is an abundance of speakers to choose from. You could get a lesser receiver or more powerful one but the price will probably be around $400 for one that you will keep. You may as well try to get better quality gear than what you had before.
  1. Denon, Yamaha or Marantz Receiver
    By spricajder in forum Home Theater/Video
    Last Post: 01-22-2009, 03:45 PM
  2. Replies: 1
    Last Post: 05-26-2004, 10:23 AM
  3. Need Advice: Building A System Piece-by-Piece On A Budget.
    By thelder in forum Home Theater/Video
    Last Post: 12-30-2003, 07:39 AM
  4. Seeking Advice on System Integration
    By BEJohnson in forum Home Theater/Video
    Last Post: 12-22-2003, 11:14 AM
