Results 1 to 25 of 106
    Jul 2002
    As did I, or I'd never have responded...and I also requested clarification of his premise...and while, as in the case of "licidity", the odd misplaced finger is excusable, the concept of "... i feel that the towers will look out of place between a screen mounted on the wall..." is a bit much, and while he may or may not be confused, my intent has been to minimize any confusion caused by the answers provided.
    It may be a bit much to you, but not to him. If he is asking the question, then a simple(or complex) answer is all that is required, no psychological evaluation is necessary. It is his speakers, and his future projector, right? Isn't it up to him to decided what looks right for him? I wasn't confused, I understood what he was trying to say, but of course I wasn't trying to be a rear orifice either?
    So what is the point? indeed...One point is, when you provide a link to a jpg, you really should include some of the more salient info contained in scenes' description...you provided pictures of a wall or baffle or whatever you might like to refer to it as, in support for your many contentions...HOWEVER...as a follow-up I visited the Sub South site and lo and behold, the transducers that were installed were Triad InWall Gold...in fact while they can be tilted up and down to tweek their dispersion(gee, that sounds like trial and error to me...anyone else?) they don't allow for toe-in, tis' fixed...so now repeat again with me...designed for...designed for...designed for a SPECIFIC USE...no simple JBLs or Tannoys or any-old-bookshelf-or-towers that just happened to be lying about.
    I was not focusing on the speakers themselves, but the baffle wall. I am sorry that you have misplaced your focus. Now let's deal with the speaker issue.
    Here is a link to at theater that uses regular boxed speakers(powered version) mounted to a baffle wall behind the screen. Notice it does not say the speaker is for wall mounting, its a studio monitor. In other words it was NOT designed specifically for baffle mounting
    The theater;
    http://www.wsdg.com/portfolio/portfol.php?SL=ht&BL=1#
    http://www.wsdg.com/popup.php?POP=ch.../home_theaters
    The speaker
    http://www.genelec.com/products/1032a/1032a.php
    Here is another theater with baffle mounted speakers. It features the JBLsynthesis two speaker system. This speaker system was also not designed specifically for baffle mounting.
    The theater;
    http://www.wsdg.com/popup.php?POP=ro.../home_theaters
    The speakers;
    http://www.jblsynthesis.com/products...=US&Region=USA
    So as you see, your theory that a speaker must be designed specifically for the purpose of baffle mounting is simple not true. The speakers I am currently using in my hometheater used to be mounted behind a baffle wall. This is nothing more than an old school narrow minded thought process that is outdated and long forgotton. Catch up with the technology!
    Well, howzabout these for a start...they are ALL THX certified. So, in no particular order, knowing full well you will find some self-serving reason to dismiss them:
    Snell XA60, XA90, XA1900 and that's just the freestanders
    Great speakers, however, the boundary compensation circuit provides only one curve, and is designed for boundaries that are close to the speakers, but not for behind a baffle wall. If we were to remain in context to this thread, we are specifically talking about boundary compensation circuits that work on a baffle wall, not for in front of walls. Just pointing out that these speakers have compensation circuit, but not specifically associated with the topic we are discussing is meaningless. The circuit is simular to the one that is found in THX controllers, and are supposed to be engaged when a non THX controller is used(it would be redundant otherwise). Not dismissing the speakers, just your understanding of what the compensation circuit can and cannot do. Baffle wall mounting will produce a very different frequency response than a speaker in a cabinet, or sitting close to a rear or side wall..
    Atlantic Technologies 4200, 6200 and 8200
    See above, same concept.
    The entire Sonance Cinema Series, save for the entry-level model
    These speakers are perfect for the task, however I see no boudary compensation circuits on them. I also do not see any information that would lead me to believe they have them.
    M&K S-150 THX Ultra's and I believe some of their LCRs are also so equipped.
    VERY familar with this speaker, and I know for a fact there are no boundary compensation circuits on this speaker. There is a radiation pattern control for wide or narrow dispersion for the tweeter. The speaker is perfect for baffle mounting, Eddie Murphy uses these in his hometheater. As far as accomodating toe in, I get my mounts that allow both up and down, and left right made for me.
    There are others if memory serves, but while they may be directed toward the HT crowd, they aren't THX certified...in fact quite a few manufacturers seem to have curtailed their licensing payments a, er...agreements and no longer produce the models listed on the THX site.
    Would you care to list the others? You memory doesn't serve me.
    And just as an aside to the general public there is a THX site which does have a wealth of info re: the subject at hand...products, placement guidelines, certification parameters...lookee here:
    www.thx.com
    There is a wealth of information there if you own THX products.
    Which really means very little...it ain't rocket science(in fact rocket science ain't all that big a deal)...particularly since the initial post had to do with how a specific scenario would affect the overall sound...you are the one who chose to bring the elephant into the room by typing THX, as though it really payed any part whatsoever. Other than to make it seem that you might have any better insight into the answer than anyone else who might dare to contribute to HAVICs information base...why shades of JR!!!
    I chose to bring THX into the picture because they advocate baffle walls for behind the screen mounting of speakers. That IMO lends credence to the practice, as they have gone through a great deal of experimentation regarding the practice for hometheater, much more than anyone else except CEDIA. Your concerns listed have already been recognized and dealt with. You say it couldn't be done without speakers designed strictly for that practice, I have proven that is already has been done, and in over a thousand TK installations all over the world. TK does not use inwalls for the front speakers, they use various box speakers just like the JBL system, and the Genelec speakers.
    I certainly have better insight into the practice than you have. I am both THX and CEDIA trained and certified, are you?
    You only really have to know the audio basics...there are facets of the hobby governed by the laws of physics which will never change. Couple that with a modicum of common sense and it's sorta' like knowing how to orienteer with topos and a compass compared to using GPS...whatta' ya' do when the batteries run out?
    Based on this comment, I suppose you can design, install, and calibrate a high end hometheater right now with the knowledge you currently have. Riiiiight! Sure you can! I am willing to bet you don't even know how to interpret the results of a real time analyzer.
    Used up your monthly allotment. did you? Pity for HAVIC it didn't occur earlier. Well, be of good cheer, it's almost Oct. 1st, and I'm sure there's more in store...and before you get all hissy-p!ssy, do recall all of your previous attempts at insult.
    My allotment didn't run out, my desire did. When you have to answer so many stupid questions in such a short time period from one particular person(RL) its a drain. Insult you, don't have to do it. Your a pro all by yourself.
    I don't claim to have any answers. The thing I do, and have always done on this site is to let all those "sheeple" in on the big secret...there are two sides to every coin and there are some folks who can't tolerate that fact and I think it's just terrible.
    jimHJJ(...all sorts of info on the web...ya' jus' gotz to look fer it...)
    The web is also full of misinformation and junk. And you are correct, there are always two sides to everything. Its terrible you have presented the more weak side. Sometime you don't have to claim anything, the arrogant attitude speaks loads. I am sure that posters on this site appreciated you calling them sheeple. I supposed you think you are a shepherd, although I would never follow you. I am not a sheeple so that might explain why.
    Sir Terrence
    Oppo BDP-103D
    9 Onkyo M-5099 power amp
    9 Onkyo M-510 power amp
    9 Onkyo M-508 power amp
    6 custom CAL amps for subs
    THX Style Baffle wall
    Nueva Jork
    You really are the best player...
    ...on my team...as I've said I treat my forays into cyberspace as learning experiences...so I took a look at your links...viola!
    Re: the Chiu and Paz HTs: the Genelec 1032s are...(listen and repeat) designed for...designed for...designed for...Multiple placement options and environments. Did you somehow miss the two lo-freq compensation switches? I didn't, there right there in the manual...congrats, would you like a Band-aid for that wound to your foot?
    Re: the May's Wilson X-1s and Watt Puppies: you aint stickin' them in walls, cutouts, baffles...he!! they won't fit in some rooms...and BTW they require installation and placement as per the Wilson installation guidelines, by a qualified dealer/rep/tech. Ain't just stickin' them any ol' place.
    Re; The Rowley's JBL synthesis lls: It is a multi-component system with the built in flexibility for placement in nearly any environment...seven-ch eq, all the bells and whistles...In fact their system controller switches driver compliment depending on the media being sourced! Of course one must also be prepared to to pay for the custom designed-mahoghany Helmholtz resonators as they might be required...
    Quote Originally Posted by TtT
    I know of no THX speaker with boundary compensation controls on them. Can you point me out a THX certified speaker system that does?
    And so I did...what those compensation citcuits can or cannot do is COMPLETLY IRRELEVANT to the subject at hand.
    No, we are specifically talking about HAVICs situation...not what he may dream of someday owning or any othe flights-of-fancy provided by you...Baffles(infinite or otherwise) weren't part of the subject nor were any THX considerations until YOU brought them up...he wants a place to hang his screen, when and if he gets one...period. Amen.
    Re: other bits of your damage control:
    Check the M&K site...you have to look, but you CAN access .pdf downloads of the manuals...no simple pictures, you have to read through the text...nearly anyone can do it...nearly...
    The THX site has a wealth of info whether or not you have THX certified gear...it's just another database, no smoke, no mirrors, no secret handshakes or hushed conversation in dark marble halls...
    IF the gear is designed for it...your "baffles" will not accomodate HAVICs PSBs...NOR the Wilson's...NOR the flagship JBL Synthesis models which have rear-firing bass ports...and to clarify again, HAVIC wants to build a wall to hang his screen BETWEEN his loudspeakers not in front of them.
    And this somehow is supposed to impress? I'm confronted with unfamiliar SOTA gear(non-audio) in my job...A few manuals and some specialized some test gear? Much ado about nothing...unless your intent is to polish your buttons...There are trained and certified techs/engineers who work on the space shuttle...two of 'em blew up if you'll recall.
    Now, I ask you...what does any of this to do re: HAVICs question?...if all you wish to do is flex your muscles and strut your THX stuff...well, IMO, you have failed...and I realize you could care one wit less of my opinion. I think you are a sham and you have nearly everyone bamboozled...the emperor has no clothes and no one should pay attention to the man behind the curtain...the great and powerful OZ has mis-spoken! Yet again.
    But(t) somehow you always succeed!
    jimHJJ(...you may want to have a doctor look at that foot...)
    Jul 2002
    Yea, maybe I should keep my foot outta your butt!
    Once again, those boundary compensation switches only help if the speaker is located IN FRONT OF THE WALL, not behind it or in it..You have a high frequency tilt control(hot helpful) bass tilt control(can't be used in a baffle situation which already boost bass), and roll off control(which presents one curve, not many and is not helpful) If you knew you stuff as much as you think you do, you would be dangerous. The is no speaker on the market that makes boundary compensation circuit for BEHIND THE BAFFLE USE, that is why equalization is necessary. Once again you are tyring to muddy the water. Here are your words;
    That is not the same as mutiple use is it?
    I wouldn't use those speakers in my installations anyway so what't the point? Why would you mention this speaker when the poster doesn't even own one? What would you castigate me for mentioning THX, and in the same thread you mention Wilson? Could you be just a little less hyprocritical?
    One again no mention of SPECIFIC anywhere huh? Thanks for the description of the synthesis system, to bad you are about 4 years to late.
    Context RL, context. We are discussing baffle mounting, so only boundary compensation circuits that apply within the context of the debate would applicable. Since we are talking about that, and not front of wall placement, your examples are faulty. Do you want to try again?
    I do believe that we are talking about baffle mounting the speakers, so whether or not the speakers compensation circuit work in that environment is relevant. Since they cannot, the circuits are usless, and irrelevant to the task at hand.
    Reason I'm thinking about a false wall is with my tower speakers 20" deep and wanting a front projector, i feel that the towers will look out of place between a screen mounted on the wall.
    I am thinking means he has not made a commitment to do it now, or later for that matter.
    but I like the front projector for the future.
    That future could be tomorrow, or twenty years from now.
    Now who's comprehension is suffering?. He was not looking for a place to hand his screen, he was talking about mounting his speakers in a false wall(I call it a baffle). Do you believe that the thrust of his question was where to hang the screen, or mounting his speakers in the baffle? Come on RL get it right man.
    His equipment may or may not be the same in the future. What you call a wall, I call a baffle. Baffle is what is used in the installation trade, wall is used by joe six packs. What the original poster proposed has already been done, I did it myself with my own speakers. Your lack of design and installation experience doesn't allow your mind to understand the concept. I have used 5 Klipsch RF-7 mounted in a baffle wall behind a screen, speakers that are larger than the original posters with excllent results. The only problem that I had was a elevated response in the mid bass and lower midrange which was easily corrected using 1/3 octave graphic eq. You are a can't do person, I am a can do. If a RF-7 can be adopted for the purpose, his PSB's can to.
    Umm, maybe you need to read the manual again. The S5000THX is the speaker with the normal and special switch, not the S-150 speaker that you mention. The S5000 is a two tweeter design, the S-150 is a three tweeter design. Get your fact straight. There is no boundary compensation circuit for the S-150. Do you wanna try again? I know that without even going to the site.
    The examples on the THX site of speaker setups is unique the the THX design. It does not comform to the industry adopted ITU-B775 setup widely used in most hometheater setups. Their setups are designed to compensate for using mismatched speakers in the front and rear hemisphere(monopole fronts, dipole rears). EX is necessary because dipoles cannot place a phantom image between the rear speakers. The ITU standards DO support phantom images across the rear soundfield. As I said earlier, they have a wealth of information if you own THX certified products. The site is dedicated to pushing THX certified products. Since you seem to know it all, I am surprised you don't know this.
    He wants to put his speakers within a baffle wall, it can be done, it HAS been done. It is up to you to disprove what has already been done. Can you do that?
    Secondly did I read this right, did you say that the JBL synthesis system cannot be used in a baffle wall setup, and the synthesis system has rear mounted ports? Wooooo. Perhaps you need to update your coke bottle bottom glasses man. All of the synthesis speaker system locate their port on the front baffle of the speaker, not the rear.
    The K2 speaker in the hercules system does locate its ports in the rear, but it is crossed over at 80hz to the sub which is well above the frequencies were the ports contribution kicks in.
    If you line up your cursor on each system, you can see the installations that these speakers have already been installed in. As you can see, all of the speakers have been placed BEHIND the screen. Each of these setups are TK designs. Every TK design uses a baffle wall. So to say the the ANY speaker in the synthesis line cannot be used in a baffle wall system is a lie. Amen!
    The two blew up because of equipment failure, not tech failure. A crack in a seal caused by cold weather, and a tile knocking a hole in the side of the ship is not a failure of the techs, but a failure of the equipment.
    Not looking to impress, just stating facts. I am sorry you don't like the facts, but facts are facts jack! We are not talking NON audio, we ARE talking audio. Not the same thing as your job, so therefore any comparison you make are apples and oranges. Every install is pretty unique, so therefore no manual is really helpful. A untrained person like yourself trying to install a high end hometheater with a couple of books and test equipment you don't understand is a receipe for diaster. Plus, no one would hire you anyway with just book knowledge.
    Well,. I think you are a stupid old man who doesn't know crap about hometheater installs. Now that we have gotten the personal stuff out of the way can we get back to the subject matter?
    ..the emperor has no clothes and no one should pay attention to the man behind the curtain...the great and powerful OZ has mis-spoken! Yet again.[/quote]
    This sounds like nothing more than jealous rantings, and someone disperately grasping at straws. Oh and you are right, I could care less of your opinion. Why would I? You have never installed one hometheater. Why should one that has listen to someone that hasn't?
    My question to you is this; How do you know something cannot work if you never tried it? How do you know if something tastes good if you never sampled it? How do you know anything if you have never studied it? If you have never tried something you are not qualified to say it cannot work. I have used the RF-7 by klipsch sucessfully in a baffle wall setup. Aside from the horn loading of the mid/tweets, the PSB is a tower speaker just like it. It has been mounted in a baffle wall, so why can't the PSB's? If a Genelec monitor, or a M&K S-150P speaker can be mounted in a baffle wall(in one of Lucasfilm's editing suites), then why can't a PSB? All kinds of speakers have been mounted behind a baffle wall, why can't the PSB?
    If I did, I learned from you. You are the biggest in the business.
    You may want a doctor to look at your foot AND your mouth.
    Sir Terrence
    Oppo BDP-103D
    Nueva Jork
    Yada, yada, yada...
    Well, once again you reveal your inability to deal in the abstract...not that this is really all that abstract. Pity you can't see Genelec's flexibility AS it's purpose. It's specific use(in this case) IS it's ability to be used in various conditions...HAVICs PSBs are what they are and that's all that they are...toot!...toot!
    Re: the Wilson's...they were included in YOUR link. I mentioned them because they, like the PSBs in question, are also what they are...do try to keep up.
    Re: the JBLs...again, it's YOUR link , so if you have a problem with its vintage, you probably shouldn't have used it. Much like the the Genelec's, their purpose is the flexibility afforded by the multi-component system approach...I don't see HAVICs PSBs in the same frame of reference.
    Re: "the future"...sorry, I let my membership in the KreskinKlub lapse. I'm trying to deal with a hypothetical situation based on at least some bit of tangible reality. Will HAVIC get his new projector? Will he build a wall for the screen? Will he decide to upgrade/change his loudspeakers? Will the point be moot? Tune in tomorrow and find out...
    If you want to dump vagaries atop possibilities and/or probabilities, be my guest...talk about grasping at straws... Given that he has listed his current gear with no mention of further upgrade...I'm gonna' take an edumacated guess that it ain't gonna' happen. Even if it does, contemplating or actual making any structural changes based on his current lineup will most likely have little or no bearing on his future choices. This alone renders the entire execise highly debatable.
    Hey, ericl...and this is a moderator...
    And TtT...sometime ago in another thread you lamented the fact of being passed over due to some issues you percieved as racial in nature...the more you post, the more the real reasons become obvious..
    jimHJJ(...color is only skin deep, being a dumb $h!t cuts straight to the bone...)
    Jul 2002
    Your operative word is SPECIFIC, not flexibility, not adaptability. Specific denotes that the speaker only works in a predictable way when placed in ONE type of environment, not many. Its disengenious for you to try and change now what you said before. Specific is specific, flexible is flexible. You cannot turn a circle into a square no matter how hard you try.
    [qoute]Re: the Wilson's...they were included in YOUR link. I mentioned them because they, like the PSBs in question, are also what they are...do try to keep up.[/quote]
    I never mentioned Wilson, so you shouldn't have. You chided me for mentioning THX even when it is much more related to this topic than wilson speakers. Stay focused, stay on topic.
    I have no problem with my link, you do have a problem with your eyes. Does all of the synthesis line have ports in the rear as you assert? No they don't. One model does, and if set up according to standards, it doesn't make a difference. M&K weren't made to be placed behind a screen or soffit, but they do just fine in that position, and have already been installed as such. Klipsch speakers were not designed to be behind a screen or soffitt, but they have been sucessfully installed in that position.A great many speakers used in custom installation were not designed for the purposed, but were adaptable to the task. The key is adaptablility, and if you have a imagination greater than a piece of white paper(that leaves you out RL) you can figure out which speakers can work in this position, and which ones cannot. The posters PSB are not a strange or weird design. The ports are on the front, the drivers all face foward, this leaves the possiblilty of many options for soffit or behind screen mounting. If you have already adopted many speakers to this position, then it is not a leap of faith to say that these could also.
    You are dodging the inaccuracies of your own statements. You said that JBL CANNOT be placed behind a screen or soffit. The link shows that it already has been done. Its much like your aurgument, you say it cannot be done except with speakers designed for this specific purposed, yet speakers of all types(not specifically designed for this purpose)have already been installed. Your argument against the practice is too late.
    According to you who seems to know all, and have done all, he is not going to get new equipment, and his speakers will not work when placed withing a wall, or behind a screen. You seem to know everything and nothing at the same time. Only you could realy pull this off, though with no success.
    Your educated guess is crap. Since you are not really educated in custom installation your advice is crap. The poster already said he was going to do more investigation, and his mind was not made up yet. His question was purely hypothetical, non committal with no timetable set. Many things can happen in that scenario. The question remains, can his PSB's be adapted to in wall placement, the answer is yes with some response corrections induced by this placement.
    You called me a sham, I didn't call out to Eric, why are you? Yes I am a moderator, but I am also a participant. You told me what you think of me, I told you what I think about you. If you cannot take it, go put on a dress, panty hose, lipstick, and a wig, sit in front of the television and watch Oprah for makeup and fashion tips. This place aint for ya!
    In another thread you spoke of failing to finish college. I am willing the bet that the same defeatist attitude you exibited in this thread, is the same attitude that didn't allow you to finish college. You also said you were too chicken to go after promotion for fear of being sued by minorities, and left hanging dry by the company. Racist if I ever heard one. Keep in mind, I have been doing custom installation for 15 years. You have done nothing even related to audio, let alone custom install. So who is really the dumb $hit, the person that has the education and experience in the field, or the old idiot who is name calling?
    Sir Terrence
    Oppo BDP-103D
    Nueva Jork
    I hesitate...
    ...to overburden your skills of comprehension any more than I already have, you leave me very little choice but to simplify matters...
    ...fewer words probably won't work...now we try NO words...pictographs better?
    http://www.genelec.com/pdf/QS2-way.pdf
    Me use "specific use" when talk about Triad InWall gold speakers...lookee-see old words:
    Quote Originally Posted by RL
    Other times used "designed for, designed for, designed for" like here:
    You no get it...big time, Joe...
    ...Klipsch speakers were not designed to be behind a screen or soffitt, but they have been sucessfully installed in that position...
    Behind screen? Has to do with what? Soffit? You hang Klipsch in soffit? Do you know what soffit is? PSBs hung in an overhang? Me no sit too close...maybe make big boom-boom on head!!! Maybe no boom-boom, just lousy image...
    You said that JBL CANNOT be placed behind a screen or soffit. The link shows that it already has been done.Does all of the synthesis line have ports in the rear as you assert?
    Me say no such thing! You bad man, you very bad man...you lying sack of $h!t...me say this:
    Oh, and one thing I should have highlighted earlier:
    Wouldn't that be in the next room? wouldn't it be so much easier to walk through the door?
    Nope, never said THAT either...you may wanna' double check your sources.
    Only because you are...
    I thought maybe he'd give you another month off...and besides doing a PM is much more appropriate...
    jimHJJ(...perhaps you should change your name to Sam...)
    Jul 2002
    Hate to bust your ignorant bubble, without measuring the response of the speaker in any position, you cannot assume that these tilt responses fit. They are offering suggestions, not specifics. Nobody installs these speakers in a studio or otherwise relying on suggestions from the site, they measure the speaker in position, in the room, and the generally use 1/3 octave eq to smooth the response. You little internet education is not enough to understand the correct installation of any speaker. Notice that it did NOT mention soffit or behind the screen application, yet the speaker was used in that fashion. Adaptability, my friend. By the way, there is nothing in your little internet surfing that would tax my comprehension, its your funny way of spelling words that does.
    You used specific use and designed for consistantly in your post. However a speaker may be designed for X placements, and can be adapted for Y position. I have already proven that was so, you have yet to prove otherwise.
    you no get it...big time, Joe...
    Who is Joe?
    What language is this? Let me get my decoder ring. This is what I mean about your obvious lack of education in this area. Here is an example of a soffit mounted speaker system,'
    http://www.genelec.com/news/cherry_beach.php
    You cannot assume that you will get lousy imaging, you have to prove it. Folks that do this for a living know how to mount the speaker in a soffit and still get good imaging. Folks like yourself who have never done a single installation would probably have a little problem hanging it in a overhang LOL
    You very stupid dried up old man, forget you say this?
    Perhaps dumb old man with all of brain and half of body in grave shouldn't talk so much if can't remember what said.
    Irrelevant to the topic at hand
    Totally irrelevant to the topic
    Well then, I think you are a stupid old geezer who doesn't know his oversized prostrate from a shoe.
    I gave myself a month off, and enjoyed it too. Pehaps you should change your name to old stupid phart. It fits you even better than Resident idiot.
    The bottom line is this, you have failed to prove that his speakers CANNOT be used in a baffle wall. You have proved that you are dumb as heck when it comes to custom installation, the language of the trade, and adpatability of speakers to different installs. The insults, meaningless words, funny spelling, and clouding the issues proves that you are in territory that is out of your reach. I suggest you go back to knitting by day, cross dress by night, and continue to watch episodes of the Desperate housewives.
    Sir Terrence
    Oppo BDP-103D
