Results 1 to 25 of 196
    Quote Originally Posted by bfalls
    Yes, I'm more than familiar with...etc.
    Then your response "After all it's all data (analog and digital)" becomes more intriguing. Presumably then, you know that accurate musical reproduction of "just data" is far more complex. Are you a critical music listener? Do you have regular exposure to the sound of live unamplified music?
    You were talking about tuning fuses in power supplies and the effects (clarity) heard.
    You are mistaken and need to review my comments. "I have totally bypassed the fuse block on an older speaker with similar improvements in clarity. " While I purchased a power fuse for my CDP, I have not as yet used it. Thus far, I have only used them in the signal path of my speakers. I will comment on the value of the power supply application once I have done it.
    I come from a more finite background where "if it can be heard, it can be measured", so your feeling and perceptions don't sway me.
    Do you really believe that metrics can fully describe the performance envelope of any audio component today?
    If you're going to jump on the bandwagon, at least learn to play an instrument.
    That instrument is my practiced ear.
