There are alot of possibilities with that budget.Listen and audition what you can.FWIW see if you can audition Rotel rsx1056 with B&W 603s3,lcr600 and 601s3.As far as subs are concerned most people rate the svs or hsu subs pretty high.I personaly have a def.tech. sub left over from my previous setup that i continue to use.
