No hesitation here to suggest Paradigm Studio's as well..especially when compared to M&K.
And as others said, unless you're wanting a sub at the level of the Servo 15 from Paradigm, look into SVS subs. At $1300-ish the Servo 15 is hard to beat, but if you're looking at the $500-$800 range then SVS is better bang for the buck.
