Results 1 to 4 of 4
    Forum Regular Walker's Avatar
    Cambridge Audio Azur 540A Question.
    I received my Cambridge audio azur 540 a yesterday, Topspeed warned me for the first 50 hours so I'm not getting in to the disappointing sound. It needs quite some break in I understand.
    Besides this I have some questions for CA azur owners.
    1: Is it normal that the Treble and Bass knobs do hardly anything?
    2: Te volume, treble and bass knobs have little blue dots on them, I thought that at least the volume knob would have a little light on it, mine does not, is this how it should be?
    3: I have to turn the volume up till about 11 'o clock to get a decent volume, is this ok or are my speakers to demanding for this amp (B&W 603 s2)
    Thanks for info,
    Walker
    Linkoping, Sweden
    Quote Originally Posted by Walker
    Make sure that the tone bypass button isn't pressed in. If it is, it won't help no matter how far you turn the nobs.
    According to Cambridge Audio, that's how it should be. I think that the neon version is much more expensive
    Walker
    That does seem quite high. How large is your listening room? The 603s should be just fine.
    There is a speaker selector (near the phones plug) where you indicate whether you're using one or two outputs. This may effect the output level. Try turning the volume down before you test that?
    Thanks Robin V,
    I called CA and was told that the bass and treble only makes a 3 db difference so that explains. It's a pitty that they didn't ad a little light on the volume knob, the light that indicate power and source are extremely bright though.
    My HK is more powerfull so I guess I'll have to just turn it up more.
    hope sound get's better after break in.
    Linkoping, Sweden
    Just hang in there Walker - it's well worth the wait.
  1. Cambridge Audio Azur 540A VS. NAD C320 BEE
    By Walker in forum Amps/Preamps
    Last Post: 01-03-2006, 03:29 PM
  2. Cambridge Azur 640C Bug
    By RobertKruz in forum General Audio
    Last Post: 05-07-2005, 09:32 AM
  3. cambridge audio azur 540d
    By musicman1999 in forum Home Theater/Video
    Last Post: 05-30-2004, 06:58 AM
  4. Cambridge Audio Azur questions
    By OP-OS in forum Amps/Preamps
    Last Post: 04-08-2004, 07:39 AM
  5. Arcam CD62T vs Cambridge Audio Azur 540C
    By xforce in forum Digital Domain & Computer Audio
    Last Post: 02-28-2004, 07:50 PM
