If you have no interest in home theater, the suggestion of an integrated amp is the way to go for best sound quality. A Cambridge Audio, NAD or maybe Jolida would be much better than a HT receiver. If you think you might want HT, your route of getting receiver and bookshelf speakers and gradually expanding is the way to go.
I think you liked Yamaha better because the HK was better able to make the Klipsch sound the way they really do. But that is a good lesson as well on how pairing certain brands can yield a desired sound, or mask one undesired. You might seek out some Paradigm speakers to listen to, they are lively without sounding harsh. They are also a very good value. Some here have said the BB brands of Athena and Insignia are good budget speakers.
