Thanks Mr. Peabody, I think with all your help I will be able to figure this one out. I will let you know how ti turns out.
Another question? The wire that I have going into my speaker are heavy duty two strand speaker wires that have no plug they are just direct wire hook ups. I have Polk speakers that handle the bare wire hook up but should I try to use the alarge screw on connector on my Polk speakers. Should I try to replace the wires with a plug in type or am I OK with just using the direct wiring system?
