You could check out some of the gear at Grant Fidelity.
They have numberous options and have well built and relatively affordable pieces.
There's the Shengya A-206 integrated amp (200w/ch) for $1650 and their CD 327A for $570 or you could try the Rita-340 tube integrated (35w/ch Class A) that's supposed to be able to drive any speaker load and it's priced at $2300.
There's more options as well but if interested I would give them a call/email to see what they would suggest.
You can visit the website: http://grantfidelity.com
Another option would be to visit the Audio Advisor site (at: http://www.audioadvisor.com/) and look at some of their offerings for integrated amps and CDPs. They often have great sales on demo, open box, refurbs, etc. You could check out some of their Vincent Audio integrateds, as well as other brands like NAD, Musical Fidelity, etc. They also have many great CDPs as well.
If possible, try to audition as much gear as possible to get an idea of what you like and then you can start familiarizing yourself with different gear, which will help when comparisons are made and it will help narrow your decision.
Good Luck and Happy listening.
