Results 1 to 3 of 3
    Jun 2014
    VGA cables - Do they carry audio?
    I plan to connect my new computer to my HDTV, which has a VGA input. Does VGA carry audio? Or do I need a separate connection for audio?
    You will need a 1/8 mini to 2-RCA cable or depending on inputs, a 1/8 to 1/8 stereo cable.
    1/8" Stereo Cable Male to Male - 6 Feet - Newegg.com
    IOGEAR G2LMMRCA006 - Newegg.com
    Note: the above links are just samples. You can spend as little or as much as you want for different levels of quality.
    Philadelphia, PA
    VGA cables/connections carry video only.
