Printable View
I plan to connect my new computer to my HDTV, which has a VGA input. Does VGA carry audio? Or do I need a separate connection for audio? http://dailydigitaldeals.info/wp-con...1/35/smile.gif
You will need a 1/8 mini to 2-RCA cable or depending on inputs, a 1/8 to 1/8 stereo cable. 1/8" Stereo Cable Male to Male - 6 Feet - Newegg.com IOGEAR G2LMMRCA006 - Newegg.com Note: the above links are just samples. You can spend as little or as much as you want for different levels of quality.
VGA cables/connections carry video only.
