Results 1 to 7 of 7
    Jun 2004
    Using RG4 Shielded Coax Cable instead of RCA for video signal (13 meters)
    Hello
    Is there a problem using RG6 Shielded Coax Cable to send a video signal from an RCA output (DVD/TV/VCR/PAY-TV) over 12 meters to a PC Capture card?
    I am planning to run the Coax under the house and put propper Coax UHF plugs on each and then using a UHF to RCA male plug's to connect the two devices?
    I am using cheapo stereo wire with rca plugs on it but was getting diagonal inteference lines in the image.
    Can a RCA/Video signal be send over Shielded Coax cable?
    Thanks in Advance
    Simon
    My Webcam: http://simon.fearby.com/webcam/
    Jun 2004
    I can't think of any reason why there would be a problem.
    Jun 2004
    Thanks wiseburro.
    I did not now if there was a signal compatibility problem with RGB video signals (12+ meters) over Shielded Coax.
    I will give it a go.
    Quote Originally Posted by FearTec
    Hello
    Thanks in Advance
    Simon
    My composite video cables have yellow RCA connectors and are labelled RG-59. This RG-59 is common coaxial cable and is the one commonly used with F-type connectors for cable TV signals. RG-6 is is the same type of cable but with higher (i.e. better)specifications than RG-59. It can carry higher frequency signals than RG-59 for longer distances due to lower capacitance and it also has better shielding.
    So the answer to your question is a resounding yes. In fact, it is an excellent choice for a 12 meter run of composite video.
    Friends help friends move,
    Jun 2004
    I have made the change to RG6 and the video quality is amazing. I still have to clean up a coax/rca plug on one end but I am very impressed.
    What type of coax would be good for sending audio signals (i think RG6 would be overkill?)
    Analog audio or digital? For digital, if it is over a long distance, you can use that RG6. Analog, use 12 ga from Home Depot, landscape wire or speaker wire are fine.
    mtrycrafts
    For analog audio, I would just buy a basic red/white RCA set of cables from any electronic retailer and for digital audio I would use a basic yellow RCA video cable.
    RG-6 would be good for extremely long distances but overkill for short runs.
  1. Does video cable length degrade a video signal?
    By Widowmaker in forum Home Theater/Video
    Last Post: 03-19-2004, 08:28 AM
  2. Does video cable length degrade a video signal?
    By Widowmaker in forum Cables
    Last Post: 03-18-2004, 07:08 AM
  3. Replies: 2
    Last Post: 01-14-2004, 07:40 PM
  4. Replies: 0
    Last Post: 01-12-2004, 01:47 PM
