• 06-11-2012, 10:26 AM
    jneutron
    Originally Posted by E-Stat View Post
    a trusted reviewer in your neck of the woods...
    If we are talking about the same person, I have family in that town now.
    Ask him about the golf tournament that goes through the yards in the community..
    followed of course, by a party.
    jn
  • 06-11-2012, 10:42 AM
    Originally Posted by Hyfi View Post
    Hopefully you realized I was being sarcastic, but it is a good read for the all cable is the same crowd.
    Uh, I do now. We need a sarcasm smilie for our more heated threads.
  • 06-11-2012, 10:58 AM
    E-Stat
    Originally Posted by jneutron View Post
    None are designed for EMC issues.
    I'm a pragmatist. The world is what it is. Cost controlled at every turn, too.
    Why would you say that? All I said was, I got a red x in a box where you linked a picture.
    Sorry, I thought it would be helpful to explain why you weren't getting the image.
    I've duplicated the valhalla.
    Matching three metrics, perhaps. I continue to disagree with the notion that is all that matters when used in real world systems.
    I did not say that lower effective dielectric coefficient, or faster prop velocity was better. Nor, worse. But different.
    Ok. Generally speaking lower EDC creates fewer interactions and phase changes than those with higher values.
    What were the numbers for both cables?
    1.33 vs 1.10.
  • 06-11-2012, 11:21 AM
    jneutron
    You'll eventually agree with me...I'm patient..:biggrin5:
    It does? Why is that?:frown2:
    Seriously, The interaction between cable length, it's EDC, it's characteristic Z and R, all conspire with the load to modify the soundstage imaging placement accuracy. Saying such a monotonic statement as you have isn't accurate. It's unfortunately, a tad more complicated than that.
    1.33 vs 1.10.
    Neat. What about the other numbers?
    jn
  • 06-11-2012, 11:41 AM
    E-Stat
    Theory sure does look good on paper!
    How do you know those are the only factors. Which one(s) have you considered and ruled out?
    I think "generally speaking" is a sufficient qualifier.
    On that we most certainly agree!
    Length was the same at ten feet or so. Z value not published for both cables. Good question. Very similar. We're not comparing 24 gauge zip to 12 gauge zip.
  • 06-11-2012, 11:55 AM
    jneutron
    It's even better when it describes a model which is an accurate predictor of an outcome.
    The list is extensive. Color, height from floor, grain boundaries, 4 9's vs 7 9's, lots of really silly stuff.
    How does one know effective dielectric constant without knowing the distributed L and C?? They conspire to create Z.
    jn
  • 06-11-2012, 12:18 PM
    E-Stat
    That is a list of silly stuff.
    It would appear that you are looking for the "characteristic impedance" as I have already provided the EDC. At least according to your definitions from five years ago.
    Click here for them
    I was referring to the use of "Z" to represent impedance in ohms. Aren't you with the plan? After all, resistance is the ONLY important factor to Roger Russell. :) In that case, the answers are 1.09 /.09 vs. 1.33 / .04
    FWIW, the values for my JPS cable are 1.16 / .05.
  • 06-11-2012, 01:04 PM
    jneutron
    Click here for them
    I know. What is L, C, and R for the cable?
    Luckily, I am not Roger Russel..
    Which is why I asked for the numbers.
    and yes, vprop =1/sqr(EDC)
    Z =sqr(L/C)
    cheers, jn
  • 06-11-2012, 01:13 PM
    E-Stat
    I know.
    But confused me by asking the wrong question.
    9.2 pF / 0.15 mH / ??? vs. 11.8 pF / .096 mH / 2.6 ohms per 1000 ft.
    Will it go round in circles?
    Will it fly high like a bird up in the sky?
    I've already told you I do not have the resistance spec for both cables! It must be too late in the day. :)
  • 06-12-2012, 05:25 AM
    jneutron
    That's a perk..
    So first cable EDC 1.33 and vprop 86.5%.
    Second EDC 1.09 and 95.5%.
    Now the unanswered question..What is the L, R, and C vs frequency?? And I know you don't have the infor, nor does the vendor. Sigh, this high end audio crew, nuttin but anarchy...
    I've got a song, ain't got no melody..
    I can't believe it. That's the first song on my playlist in the office...
    jn
  • 06-12-2012, 05:31 AM
    E-Stat
    I get the value of EDC and glad you concur with my math - theoretical goal of matching "perfect" dielectric of 1 to reduce time/phase distortion. What does the "characteristic impedance" tell you? Is .05 better than .09 or vice versa? Why?
    Bonus! :)
  • 06-12-2012, 05:57 AM
    jneutron
    First cable 127 ohms, second 90 ohms, given the numbers you present.
    When a cable is constructed with parallel insulated conductors in a wide form factor, the magnetic field path is increased, increasing reluctance. This lowers the inductance per unit foot, but introduces susceptibility to freuqncy based changes in inductance. Proximity effect will cause the outer conductors to begin "shying away" from carrying current, and as a result, the inductance will lower with frequency and the resistance of the cable will begin to increase.
    What is .05 and .09?
    jn
  • 06-12-2012, 06:10 AM
    E-Stat
    What is the significance, if any, between those values?
    jn
    Operator error. First due to fumble fingers on calculator. Overall, I used mH as specified rather than nH. Difference in magnitude.
  • 06-12-2012, 06:23 AM
    jneutron
    For the base numbers, it determines the settling time for the cable/load system. Since we're dealing with loads which are orders of magnitude lower than what the cable impedance is, the number of reflections necessary to get to 80/90% of final value will change.
    The caveat with the valhalla is what proximity effect on the cable width has on the cable Z vs frequency.
    Ah, ok. For numbers large enough to require me taking my shoes off, I try to repeat the calcs many times.. sometimes it works...
    jn
