Results 1 to 25 of 114
    Quote Originally Posted by jneutron View Post
    None are designed for EMC issues.
    I'm a pragmatist. The world is what it is. Cost controlled at every turn, too.
    Why would you say that? All I said was, I got a red x in a box where you linked a picture.
    Sorry, I thought it would be helpful to explain why you weren't getting the image.
    I've duplicated the valhalla.
    Matching three metrics, perhaps. I continue to disagree with the notion that is all that matters when used in real world systems.
    I did not say that lower effective dielectric coefficient, or faster prop velocity was better. Nor, worse. But different.
    Ok. Generally speaking lower EDC creates fewer interactions and phase changes than those with higher values.
    What were the numbers for both cables?
    1.33 vs 1.10.
    Nov 2002
    You'll eventually agree with me...I'm patient..
    It does? Why is that?
    Seriously, The interaction between cable length, it's EDC, it's characteristic Z and R, all conspire with the load to modify the soundstage imaging placement accuracy. Saying such a monotonic statement as you have isn't accurate. It's unfortunately, a tad more complicated than that.
    1.33 vs 1.10.
    Neat. What about the other numbers?
    jn
    Theory sure does look good on paper!
    How do you know those are the only factors. Which one(s) have you considered and ruled out?
    I think "generally speaking" is a sufficient qualifier.
    On that we most certainly agree!
    Length was the same at ten feet or so. Z value not published for both cables. Good question. Very similar. We're not comparing 24 gauge zip to 12 gauge zip.
    Nov 2002
    It's even better when it describes a model which is an accurate predictor of an outcome.
    The list is extensive. Color, height from floor, grain boundaries, 4 9's vs 7 9's, lots of really silly stuff.
    How does one know effective dielectric constant without knowing the distributed L and C?? They conspire to create Z.
    jn
    That is a list of silly stuff.
    It would appear that you are looking for the "characteristic impedance" as I have already provided the EDC. At least according to your definitions from five years ago.
    Click here for them
    I was referring to the use of "Z" to represent impedance in ohms. Aren't you with the plan? After all, resistance is the ONLY important factor to Roger Russell. In that case, the answers are 1.09 /.09 vs. 1.33 / .04
    FWIW, the values for my JPS cable are 1.16 / .05.
    Nov 2002
    Click here for them
    I know. What is L, C, and R for the cable?
    Luckily, I am not Roger Russel..
    Which is why I asked for the numbers.
    and yes, vprop =1/sqr(EDC)
    Z =sqr(L/C)
    cheers, jn
    I know.
    But confused me by asking the wrong question.
    9.2 pF / 0.15 mH / ??? vs. 11.8 pF / .096 mH / 2.6 ohms per 1000 ft.
    Will it go round in circles?
    Will it fly high like a bird up in the sky?
    I've already told you I do not have the resistance spec for both cables! It must be too late in the day.
