Am I the only one here who would not consider wire and cables a system component.
Can your system work without it? NO? Can it change the sound? Yes! Then it is a system component.
Does it make as big a difference as speakers? It is all relative. Cables are more of a tweak. Do you use the skinny little cables that came with your components? I doubt it. If there was no difference we would all be using them and be happy.
I think that is what Mr P was trying to say is that there is a difference and no-one can truly believe there isn't. From that point on it all depends on you and your ears as to what you should spend your money on.
