Please correct me if I'm wrong, but there should be a fuse inside the amplifier and electric current has to pass safety fuse before power supply. If you look at inside the fuse there's only tiny string of wire corresponding to the max ampere it can take. So there is no point of adding heavier power cable if ended up limited by the fuse.
